10-10-2018 07:51 AM - edited 07-05-2021 09:16 AM
I understand the AIR-AP1832I-x-K9C (With the 'C' at the end) comes default with Mobility Express on the AP.
What is the process to join this to a controller instead of using Mobility Express? Is it just the normal process of tossing it on the network and letting it find the join the controller via DHCP?
Or does the firmware have to be flashed to a different version?
Solved! Go to Solution.
10-10-2018 07:53 AM
10-10-2018 07:53 AM
