Aironet 350 PCMCIA WiFi CARD
ucc806
I'm having a problem with a Cisco Aironet 350 WiFi PCMCIA Card (speed has to be auto) installed in a Sony Camera and intermittently not connecting to a ZyXEL ZyAIR G-110 WiFi PCMCIA Card (speed set to b only (which is 11 MBPS))which is installed in a Dell Laptop. On startup (laptop first then camera) it sometimes connects and sometimes doesn't. The ZyAir card is always fully initialized first then the Aironet is initialized.
What I also noticed that was strange is that if you toggle (fn + F2) the Centrino WiFi NIC (built into the laptop) on and then off the Aironet suddenly establishes connectivity.
a-vazquez
Level 6
Level 6
If you use a non cisco card you can NOT use any Cisco enhancements to the standards including LEAP or 128 WEP. 40 Bit WEP will work fine as long as your card supports it.
Try:
http://www.cisco.com/web/about/ac123/ac147/archived_issues/ipj_5-1/ieee.html
