Aironet IE and Mesh Netowrk
aous.salloum
Hi Guys,
I am planning to disable Aironet IE on our WLC, it's running mesh
is there a risk that when I disable Aironet IE mesh points disassociate and have a big outage ?
Cheers,
Hi @aous.salloum
 Don't think so.
By definition:
"Aironet IE is a Cisco proprietary attribute used by Cisco devices for better connectivity. It contains information, such as the access point name, load, number of associated clients, and so on sent out by the access point (AP) in the beacon and probe responses of the WLAN. The Cisco Client Extensions (CCX) clients use this information to choose the best AP with which to associate."
So, this is an additional field on beacons in order to try improve interoperability between AP and client. It is useful for Cisco IP phone and can be a problem for some non-cisco clients. Usually I disable it.
 I really don't believe you can have problem in mesh by disabling it.
-If I helped you somehow, please, rate it as useful.-
