All acces point ares same channel 36 with 5 gh band
Dhikra Marghli
Level 5
Level 5
Hello
i have all acces point are same channel 36 with 5 gh band
i would to know if correcte , it ok for this all  access point  are same channel ? can give a problem or not ?,
please , i would some one answer me for this problem !! and i would what solution if al acces point give e problem !!
thanks in advanced
2 Accepted Solutions
1. DCA must be set to automatic.
2. If APs coverage area are not overlaping then it will not be an issue if they are on same channel.
Dont forget to rate helpful posts
Also..enable CleanAir:  it will detect and classify interferers.
EDRRM: It  will allow the WLC to change channels and/or lower the power of the AP to minimize the effects of co-channel interference.
Dontf orget to rate helpful posts
11 Replies 11
Dhikra Marghli
Level 5
Level 5
i would to know if all 26  acces point ares same channel 36 in band 5 gh is Ok or NOT ???????????,
if that is impact the problem so what is the solution that i can do !!!
please i need a help
marce1000
 - Describe you Wifi-architecture , Standalone AP's , controller-based, Mesh , Meraki --- ? Please elaborate!
M.
Wifi-architecture: infstracture based a controller 3504 cisco and 26 acces point 1815i
two fortigate ( primary and backyp )  as servers DHCP and two router cisco 2921 primary and bacup to network wan
that is hardware
can you tell me it is normal all 26  acces point are same channel !!
what solution can you give me !!
 - Check wether DCA Is set to automatic , should be the default (unless someone tempered with it); also check the thread below :
 https://community.cisco.com/t5/wireless-and-mobility/controller-places-ap-s-on-same-channel/td-p/2125274
M.
it is automatic DCA and other paramter also id by default
please can you give a team view to chek controller !!
and i would to know if it is normal all acces point in band 5 gh all same channel !!  so what i can check other
thanks
can you tell me   if it is normal to have  all acces point in band 5 gh all same channel  36  !!  so what i can check other
thanks in advance
can you give any information to chek this sitauation and i wait to answer me now beacuse we have in Tunsia event arab
please help me to know this infastrctre is correct
thanks in advance
i need a help
thanks in advance
