All of AP controllers are same commands?
Soon Kwan Kwon
Hello all,
I have AIR-CT5508.
Because I don't control CT5508, I searched on the internet and got a manual.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0/configuration/guide/c70/c70ccfg.pdf
The following ↑ manual is supporting CT5508's command?
SK
Rasika Nayanajith
HI SK,
You need to choose it based on the software version you run on your 5508. Here is the link to configuration guides and pick the right version according to your deployment
http://www.cisco.com/c/en/us/support/wireless/5508-wireless-controller/model.html#ConfigurationGuides
Here is command references
http://www.cisco.com/c/en/us/support/wireless/5508-wireless-controller/model.html#CommandReferences
Rasika
*** Pls rate all useful responses ****
Thank you Manannalage!
It is helpful data^^
