Allowing only TACACS authentication for wireless users
Abinaya R
I have integrated WLC 5508 version 7.0 with Cisco ACS. I have enabled TACACS authentication. So, user can login through TACACS user credentials.
The default admin user details are used as local authentication. My requirement is the users should login through TACACS only. At this time, local admin user details should not be enabled. Only in case of failure of ACS, the users should use the local authentication.
May i know how should i proceed for this requirement?
Abinaya R
This requirement is for logging into the WLC
follow the steps that you see in this link.
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70sol.html#wpmkr1261131
You just use tacacs as first option and then local.
It will only fall back to local if tacacs is not recheable.
Let us know if it answer your question, dont forget to rate thepost and to mark it as solved.
