An urgent query AIR-BR1310G-E-K9
waqas.ashraf
Dear all,
i have some queries,please help me out
1. AIR-BR1310G-E-K9 wireless bridge, which has an integrated antenna can be connected to AIR-ANT19491? If yes then how?
2. If not then i searched and found that AIR-BR1310G-E-K9-R is compatible with it but are the connectors or the cable to connect them have to be ordered seprerately, or are they included in the above mentioned prodects.
It is a bit of an urgent problem i will appreciate the quick and prompt responses.
thanks.
Rob Huffman
Hi Wagas,
You are on the right track here. The AIR-BR1310G-E-K9 has an Integrated antenna and cannot be connected to the AIR-ANT19491.
The AIR-BR1310G-E-K9-R is compatible with the AIR-ANT19491 and comes with the appropriate RP-TNC connector. The Low Loss cable and Antenna have to be ordered separately.Here is the ordering information;
AIR-BR1310G-E-K9 = The Cisco Aironet 1300 Series Outdoor Access Point or Bridge features an 802.11g 2.4-GHz radio, which supports data rates up to 54 Mbps. With this option, a 13-dBi patch antenna is integrated into the ruggedized enclosure
Cisco Aironet 1300 Series Outdoor Access Point or Bridge with integrated patch antenna
Cisco IOS Software
Ships with:
Power cord (configurable)
100 to 240 VAC power supply (AIR-PWR-A=) providing 48 VDC to the power injector
48 VDC power injector (AIR-PWRINJ-BLR2=)
1-ft dual RG-6 cable assembly (Ethernet uplink from power injector)
Roof Mount Kit available separately (AIR-ACCRMK1300=)
AIR-BR1310G-E-K9-R = A connectorized version of the Cisco Aironet 1300 Series Outdoor Access Point or Bridge provides professional installers with RP-TNC type connectors that allow the deployment of nodes with omnidirectional, sector, or high-gain dish antennas for custom installations
Cisco Aironet 1300 Series Outdoor Access Point or Bridge with RP-TNC type connector
Cisco IOS Software
Ships with:
Roof Mount Kit (AIR-ACCRMK1300=) and Wall Mount Kit (AIR-ACCWAMK1300=) available separately
Optional 5-ft, 2.4-GHz RF jumper cable available separately
Antennas available separately
ANTENNAS FOR CISCO AIRONET 1300 SERIES OUTDOOR ACCESS POINT OR BRIDGE WITH RP-TNC TYPE CONNECTORS
AIR-ANT2414S-R1 Cisco Aironet 2.4-GHz, 14-dBi sector antenna
AIR-ANT2506 Cisco Aironet 2.4-GHz, 5.2-dBi omnidirectional mast-mount antenna
AIR-ANT241201 Cisco Aironet 2.4-GHz, 12-dBi omnidirectional mast-mount antenna
**AIR-ANT19491 Cisco Aironet 2.4-GHz, 13.5-dBi Yagi antenna**
AIR-ANT2410Y-R Cisco Aironet 2.4-GHz , 10-dBi Yagi antenna
AIR-ANT33381 Cisco Aironet 2.4-GHz, 21-dBi dish antenna
AIR-ANT3549 Cisco Aironet 2.4-GHz, 9-dBi patch antenna
**Antennas must be ordered separately**
AIR-CAB005LL-R Cisco Aironet 5-ft, low-loss, 2.4-GHz RF cable with RP-TNC connectors
From this good doc;
http://www.cisco.com/en/US/products/ps5861/products_data_sheet09186a008022198b.html
Hope this helps!
Rob
Please remember to rate helpful posts.....
Rob Huffman
Hi Wagas,
Cisco IOS Software
Ships with:
Cisco IOS Software
Ships with:
From this good doc;
Hope this helps!
Rob
