Analysing 2.4Ghz and 5Ghz simultaneously with Cisco Spectrum Expert
mcollins1983
I was wondering if it's possible to review the spectrums of both 2.4Ghz and 5Ghz at the same time using Cisco Spectrum Expert?
Thanks.
Hi @mcollins1983
With external USB antenna I believe so. With Cisco Access Points it is not as you have to choose the band right on the connection.
-If I helped you somehow, please, rate it as useful.-
