Anchor Controller 9800
fahad.razzaq
Frequent Visitor
Frequent Visitor
i  introduce anchor controller in network for guest traffic this anchor placed in DMZ -  modle C9800
Foreign Controller is already placed in Data center for User traffic.
i understand Mobility tunnel and capwap tunnel sever different purpose on different network ports.
so my question do i required seprate VLAN for mobility tunnel or i can use same VLAN which i am using as WMI.
Mark Elsen
  - @fahad.razzaq     You will need a separate network (and or VLAN) for the mobility tunnel between the controllers ,
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
