Anchor Foriegn WLC routing
ittechk4u1
Level 4
Level 4
Hello experts,
What is required from routing perspective between AncHor WLC(DMZ) and foreign WLC (Internal).
which ports ?
is there anything else required to setup anchor/foreign setup?
Prateek Saxena
You must allow these ports on the firewall
  • Legacy mobility: IP Protocol 97 for user data traffic, UDP Port 16666
  • New mobility: UDP Port 16666 and 16667
You can verify the same by doing 'mping <ip>' and 'eping <ip>' from the WLC to verify the reachability
