anchor ssid
suthomas1
Level 7
Level 7
Hi, What is the method to verify what ssid is a mobility anchor group using? We have a mobility tunnel whose one end wlc(5508) will be changed shortly, which will need some changes on the tunnel I believe. Before this is done, we will need to do some checks to ensure this works right. appreciate all help.
Rasika Nayanajith
If you run "show mobility anchor wlan" you will get list of WLAN configured for Mobility Anchor
(BUN-PW00-WC01) >show mobility anchor wlan
Mobility Anchor Export List
 WLAN ID     IP Address            Status
 15          10.10.6.244          Up
Is this you looking for or something else ?
Rasika
*** Pls rate all useful responses ***
Saravanan Lakshmanan
from foreign wlc we can see to what wlc it is anchored to but vice versa cannot be seen since it is locally terminated and also dynamic in nature per client basis, however can see the foreign wlcs from mobility member list of anchor.
