Anchoring between major code levels?
mscherting
Level 5
Level 5
Hello all.
I want to upgrade my core WiSM-2's to 7.4.110 take advantage of some of the new features.  They're currently running 7.0.235.
I also have some 4402 and NME/WLC-25 WLCs whose guest WLANs are anchored back to the WiSM-2's.
Will the anchored guest services continue working with this wide disparity between code levels?
Thanks!
George Stefanick
Yes check the ircm section .. I have 7.4 anchored to 7.0240 no issues ..
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
George Stefanick
Great!  Thanks!
