Android ver 5 problem Connecvtivity witch Cisco WiFi Network
vpergament
Hello
All our developers that upgraded their Nexus devices from Android version 4 to Android version5 , can't connected to Office Network using PEAP or EAP-TLS authentication even Radius logs show that authentication was successfully. On the same time Mobile devices with Android 5 can connected to Guest WiFi network without any problem
Our WiFi Network use
  • Cisco WiFi Controller version 7.2.110.0
  • Cisco WiFi AP 3502
I also attach client debug information from controller
Does any one have successfully experience with Connection Android 5 to Cisco WiFi Infrastructure by PEAP or EAP-TLS
Thank you for any help and information's
Victor.
Thank you very much for your help.
I have opened TAC .
There are problem on the version 7.2.110.0 that I use on my controller
Bug CSCua29504
https://tools.cisco.com/bugsearch/bug/CSCua29504
Currently I used Workaround solution
Use WPA/TKIP or WPA2/TKIP instead. Note that this will limit the client
to 802.11g/802.11a data rates.
I am Planning Upgrade Controller on the next week. to new version.
Saurav Lodh
Level 7
Level 7
can you disable the MFP ?
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_0111001.html
I have opened TAC .
Bug CSCua29504
Michael Glenn
Seems to be a configuration issue with Android 5.0. No official fix yet. See https://code.google.com/p/android/issues/detail?id=78702
