Another Bonjour issue
Claudio Motta
Community Member
Hi all,
I need hel pin configuring Bonjour on a 2504 controller with 7.5.102.0 fw.
The controller is connected to a 2960S switch with 15.0(1)SE2.
The antennas, all AIR-LAP1242AG-E-K9, are connected to this and other 2960 (same sw).
I followed step by step this documents:
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_tech_note09186a0080bb1d7c.shtml (only multicast-muticast suported by my Wlc)
http://www.cisco.com/en/US/docs/wireless/technology/bonjour/Bonjour_Deployment.html
But without success.
Now i'm fighting with the manager that says that is impossible that on his home 30$ access point works and on our net not... you can immagine
Thank you,
Claudio
Rasika Nayanajith
Since you are usng WLC 7.5.102.0 firmware here is most upto date deployment guide for this feature. Hope it is useful.
http://www.cisco.com/en/US/docs/wireless/technology/bonjour/7.5/Bonjour_Gateway_Phase-2_WLC_software_release_7.5.html
Regarding the last comment, Apple introduced this for home/consumer environment where you will work with single vlan (or unmanaged home grade switch) using link local multicast feature (mDNS). Since then users demanding to bring those sort of thing into enterprise environment (consist of multiple l3, restrictive, etc) and all wireless vendors try to support it & it is not straight forward as of home environment. That's why even Cisco improving this feature satring from 7.3, 7.4 & 7.5 codes, still may not perfect how you want it.
Rasika
**** Pls rate all useful responses ****
