ANT5959 Installation problem
j.beckner
Level 3
Level 3
We just installed two AP1200 with ANT 5959 in biology and chem labs at a college. The system works fine. The ANT5959 is designed to clip onto the ceiling tile t-bar of a drop ceiling. The problem we have is that they sag slightly (about quarter inch) on the opposite side from the clips. We were thinking of using Velcro, anyone have other suggestions?
j.beckner
kmarrero
Level 8
Level 8
Velcro is a pretty good idea for getting the antenna closer to the ceiling tile. I would imagine that if you have the cables going through the ceiling tile you could possibly put some zip ties around the cable after it has been placed through the ceiling tile to hold the antenna closer to the tile.
