Antenna alignment
mikespenard
Community Member
My hardware...
Cisco 1300 12.3
Cisco Command Referance states......
#dot dot11 antenna-alignment
Use the dot11 antenna-alignment privileged EXEC command to activate the antenna-alignment tool for an radio interface. Use this tool to test and align the access point antenna with another remote antenna.
dot11 interface-number antenna-alignment [timeout]
Examples
This example shows how to start the antenna-alignment test for radio interface 0:
AP# dot11 dot11radio 0 antenna-alignment
Issue:
AP1#dot dot11 0 ?
carrier Carrier detect test
linktest test the radio link
update-group-key Update Group Key
AP1#dot11 dot11Radio 0 antenna-alignment
% Invalid input detected at '^' marker.
Why is the command not supported on my accesspoint?
Do i have to be in install mode?
7 Replies 7
dixho
Level 11
Level 11
You need to set the 1310 either at non-root bridge or workgroup bridge.
In my other posting, I explain why access point mode does not support the command.
I have my nonroot bridge in - wait for it - non root bridge mode, and when I run antenna-alignment I get the following:
NonRoot#dot11 dot11Radio 0 antenna-alignment
Can you shed any light on why I cant run the command?  I am using Cisco 1200 G APs for root and nonroot.  See below screenclips:
Message was edited by: Jonathan Hoffmann for clarification
What's your WAP model again?
its a pair of
cisco AIR-AP1231G-A-K9
both running
Cisco IOS Software, C1200 Software (C1200-K9W7-M), Version 12.3(8)JED1, RELEASE SOFTWARE (fc3)
I believe you need to have 1310.
the command is listed in the 1200 command reference - and when I run sh antenna-alignment, it says it hasnt been run yet.
http://www.cisco.com/en/US/docs/wireless/access_point/12.2_8_JA/command/reference/bcrmain.html#wp2439534
Good morning to all. I see that this POST is 04 years old, but I want to update it. I have a median installed base of Cisco Aironet 1310 due to connectivity problems between the AP and NON-ROOT ROOT, I wanted to use the "antenna-aligment" command but it shows me the error showing.
BR-TFASE5BK-5#dot11 dot11Radio0 antenna alignment
BR-TFASE5BK-5#
The version of IOS:
BR-TFASE5BK-5#sh ver
Cisco IOS Software, C1310 Software (C1310-K9W7-M), Version 12.4(25d)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 11-Aug-11 03:35 by prod_rel_team
ROM: Bootstrap program is C1310 boot loader
BOOTLDR: C1310 Boot Loader (C1310-BOOT-M) Version 12.3(2)JA4, RELEASE SOFTWARE (fc1)
BR-TFASE5BK-5 uptime is 6 days, 22 hours, 44 minutes
System image file is "flash:/c1310-k9w7-mx.124-25d.JA1/c1310-k9w7-mx.124-25d.JA1"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-BR1310G-A-K9-R (PowerPCElvis) processor (revision A0) with 25590K/7168K bytes of memory.
Processor board ID FTX1145U09A
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1D:A2:E4:91:FE
Part Number : 73-8960-09
PCA Assembly Number : 800-24963-06
PCA Revision Number : A0
PCB Serial Number : FOC1139409V
Top Assembly Part Number : 800-28763-01
Top Assembly Serial Number : FTX1145U09A
Top Revision Number : A0
Product/Model Number : AIR-BR1310G-A-K9-R
Configuration register is 0xF
BR-TFASE5BK-5#
Interface:
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
encryption vlan 15 mode ciphers tkip
ssid LNK-TRU-DIS
antenna gain 12
parent 1 001d.a2ef.3a70
parent timeout 30
station-role non-root
mobile station scan 2462
Please any ideas about what append.
Regards.
Fernando.
