Antenna Diversity Question
jclay
Community Member
Are there specific distances that antennas should be placed to maximize the benefit of antenna diversity in an 802.11b compliant WLAN?
jaunger
Community Member
Are you refering to antennas on an indoor access point or to antennas that are outside, say
on a roof?
ED CARMODY
Level 5
Level 5
Usually recommended is 10-20 wavelengths. A wavelength is a couple of inches at 2.4GHZ.
For the type of fading that 802.11b is trying to combat, the signals from two antennas separated by even a wavelength are largely uncorrelated. Hence, even very small separations work.
The spacing is non-critical. Since the receiver is only using one antenna at a given time, you don't have to worry about the phase relationship between the two antennas. If you were using two antennas at once (typical in two-way radio and broadcast TV/FM, etc.), the spacing and length of feedlines is critical because there the phase matters.
