Antenna Gain
dimensyssrl
Level 5
Level 5
Hello.
I have a question about Antenna Gain on WLC (sw version 7.0).
We have installed external diversity antennas, we'd like to configure antenna gain to reflect productor indications; into manual is indicated that this parameter is not configurable, but into configuration menu is configurable.
I attach screenshots.
Anyone can help about this?
Daniele
Scott Fella
I never really change that, but if you have an antenna that is 5.5dbi gain, you double that (x0.05) and you would enter 10 in the field.  It suppose to help the WLC make power level changes better since it will not know of your antenna gain.  If you have basic 2.2dbi, just leave that at 0.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Thank you for reply.
But my question is: manual indications are wrongs?
Daniele
You can open a TAC case and have them note it.
-Scott
