Antenna Selection
iain.mccutcheon
Community Member
I have a wireless link running at 5.4GHz over a city centre, it is only around a distance of 30m. What antennas are going to run this very short link with no problems?
(Gain levels etc are obviously an issue).
There is also an issue with the weather, snow and ice settles on the antenna and often interferes with the signal/orientation.
They are being ran from 1242AGs.
Thanks.
amritpatek
Level 11
Level 11
Here is the URL for the Antennas and Accessories it may help you for the Antenna selection
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008022b11b_ps5279_Products_Data_Sheet.html
