Antenna Selection
YuMon
Frequent Visitor
Frequent Visitor
I am looking for antennas for C9124AXE APs and am having a hard time confirming AIR-ANT2524DW-R models work with C9124AXE APs.
According to below document ,AIR-ANT2524DW-R is not included in「9124AXE Access Point Supported External Antennas」list.
Cisco Catalyst 9124AX Series Outdoor Access Point Hardware Installation Guide - Hardware Features [Cisco Catalyst 9124AX Series] - Cisco
Does the AIR-ANT2524DW-R antenna work with the C9124AXE series APs?
What kind of risks and additional devices would i need?
Leo Laohoo
AIR-ANT2524DW-R will not fit into a C9124AXE.
C9124AXE Supported External Antennas
YuMon
Frequent Visitor
Frequent Visitor
Thank you so much.
JPavonM
You need to look for N-type antenna models only from Cisco or AccelTex. In Cisco, the part numbers end with "-N". For AccelTex  check here.
