antenna
o.hassairi
Level 5
Level 5
hello
if i have an AP350 without fixed antenna.
can i use the antenna provided by PCI wireless cards? has it the same power?
generally, if we use 2 antenna is it better than using one ?
blue.modal
Level 6
Level 6
The PCI card should have an antenna with an RP-TNC connector, which will work on a Cisco (or LinkSys) AP or Bridge.
The instances where you truly *need* a second antenna are rare.
If you are scrounging for cheap parts, third-party antennas with RP-TNC connectors are readily available.
Matthew Wheeler
Chief Wireless Architect
www.BlueModal.com
