Anyone still using Peer to Peer Blocking on WLAN
trapasso
I work at a University and I have always had P2P blocking set to Drop.  With all the students it was piece of mind.  I have just been asked if it is relevant.  I personally still think P2P blocking is relevant and maintains a nice security posture but I am curious what other think.
Do people still set P2P blocking or do you just disable it?
15 Replies 15
Scott Fella
We have it enable just to check box a security ask. Issue is even with central switching is if you have multiple controller is an N+1. If you have SSO and the ap’s will not join another controller, then it works as expected. I have ran Flex so this as you know will not work. I’m still not a fan of SSO so ap’s have the possibility of joining an N+1 controller.
-Scott
