AP 1042 is not registering in wlc 4404 controller
previously these Ap1042 is registered with Wlc 4404
But Now it getting restrat every time
the output of  console as show below
flashfs[0]: 27 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 7382528
flashfs[0]: Bytes available: 25002496
flashfs[0]: flashfs fsck took 24 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: e0:5f:b9:d6:f9:a6
Ethernet speed is 1000 Mb - FULL duplex
Loading "flash:/c1140-k9w8-mx.124-23c.JA10/c1140-k9w8-mx.124-23c.JA10"...########################################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1140-k9w8-mx.124-23c.JA10/c1140-k9w8-mx.124-23c.JA10" uncompressed and installed, entry point: 0x4000
executing...
enet halted
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C1040 Software (C1140-K9W8-M), Version 12.4(23c)JA10, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 20-Mar-15 12:27 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
FLASH CHIP: Numonyx P33
Checking for Over Erased blocks
flashfs[1]: 27 files, 8 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32126976
flashfs[1]: Bytes used: 7382528
flashfs[1]: Bytes available: 24744448
flashfs[1]: flashfs fsck took 7 seconds.
flashfs[1]: Initialization complete.
flashfs[2]: 0 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 11999232
flashfs[2]: Bytes used: 1024
flashfs[2]: Bytes available: 11998208
flashfs[2]: flashfs fsck took 0 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
00:00:10 UTC Fri Mar 1 2002: Unexpected exception to CPUvector 200, PC = 0x51377C , LR = 0x5141D4
-Traceback= 0x51377C 0x5141D4 0x5148B8 0x4FBE60 0x4FC268 0x4F8C70 0x1912FC 0x1913B0 0x57090 0x57398 0x1A62D0
CPU Register Context:
MSR = 0x00029230 CR = 0x24000028 CTR = 0x004FBD94 XER = 0x00000000
R0 = 0x9400AE16 R1 = 0x012D9E28 R2 = 0x00000000 R3 = 0x012D9F48
R4 = 0x00000008 R5 = 0x012D9F58 R6 = 0x00000000 R7 = 0x012D9F40
R8 = 0x4B233FAE R9 = 0x00000000 R10 = 0xBD912F2B R11 = 0x009C7CE2
R12 = 0x9F2CCB80 R13 = 0x01000000 R14 = 0x00000000 R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
R24 = 0x00000000 R25 = 0x00000000 R26 = 0x00000000 R27 = 0x00C1258C
R28 = 0x012D9F58 R29 = 0x00000000 R30 = 0x012D9F50 R31 = 0x012D9F48
SRR0 = 0x00174260 SRR1 = 0x00029230 SRR2 = 0x0051377C SRR3 = 0x00029230
ESR = 0x00000000 DEAR = 0x00000000 TSR = 0x84000000 DBSR = 0x00000000
=== Flushing messages (00:00:11 UTC Fri Mar 1 2002) ===
Buffered messages:
Queued messages:
*Mar 1 00:00:11.831: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar 1 00:00:11.708: %SYS-4-PUPDATECLOCK: Periodic Clock update with ROMMON failed, because size left in ROMMON (4294967295), size needed (29), error code (-1)
Nested exception_rom_monitor call (2 times)
Unexpected exception to CPUvector 200, PC = 51377C
Exception (200)! Machine Check
ESR: 0x00000000, BESRA: 0x00000000, BESRB: 0x00000000, BEAR: 0xFFFFFFFF
MSR: 0x00020030, SRR2: x002B086C, SRR3: 0x00020030
Vector = 0x00000200 PC = 0x0051377C MSR = 0x00029230 CR = 0x24000028
LR = 0x005141D4 CTR = 0x004FBD94 XER = 0x00000000
Stack trace:
PC = 0x0051377C, SP = 0x012D9E28
Frame 00: SP = 0x012D9E38 PC = 0x00C12300
Frame 01: SP = 0x012D9ED8 PC = 0x005141D4
Frame 02: SP = 0x012D9EE0 PC = 0x005148B8
Frame 03: SP = 0x012D9F60 PC = 0x004FBE60
Frame 04: SP = 0x012D9F80 PC = 0x004FC268
Frame 05: SP = 0x012D9F88 PC = 0x004F8C70
Frame 06: SP = 0x012D9F90 PC = 0x001912FC
Frame 07: SP = 0x012D9FB0 PC = 0x001913B0
Frame 08: SP = 0x012D9FD0 PC = 0x00057090
Frame 09: SP = 0x012DA0D8 PC = 0x00057398
Frame 10: SP = 0x00000000 PC = 0x001A62D0
ap uptime is 14 seconds
cisco AIR-LAP1042N-E-K9 (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FCZ1504W478
PowerPC405ex CPU at 333Mhz, revision number 0x147E
using eeprom values
WRDTR,CLKTR: 0x82000800 0xc0000000
RQDC ,RFDC : 0x80000039 0x0000018f
ddr init done
Running Normal Memtest...
Passed.
IOS Bootloader - Starting system.
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x82000800, 0xc0000000
RQDC, RFDC : 0x80000039, 0x0000018f
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is up.
PCIE1: VC0 is active
PCIEx: initialization done
executing...
enet halted
cisco Systems, Inc.
Buffered messages:
Queued messages:
*Mar 1 00:00:11.833: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar 1 00:00:11.709: %SYS-4-PUPDATECLOCK: Periodic Clock update with ROMMON failed, because size left in ROMMON (4294967295), size needed (29), error code (-1)
Stack trace:
using eeprom values
ddr init done
Passed.
PCIE0: link is up.
PCIE1: link is up.
executing...
enet halted
cisco Systems, Inc.
Buffered messages:
Queued messages:
Stack trace:
using eeprom values
ddr init done
Passed.
PCIE0: link is up.
PCIE1: link is up.
executing...
enet halted
cisco Systems, Inc.
Buffered messages:
Queued messages:
Stack trace:
using eeprom values
ddr init done
Passed.
PCIE0: link is up.
PCIE1: link is up.
i try for mode button also i got same output as shown below
using eeprom values
ddr init done
PCIE0: link is up.
PCIE1: link is up.
flashfs[0]: flashfs fsck took 25 seconds.
button pressed for 5 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
executing...
enet halted
cisco Systems, Inc.
R12 = 0x9F2CCB80 R13 = 0xFFFFFF7F R14 = 0x00000000 R15 = 0x00000000
Buffered messages:
Queued messages:
*Mar 1 00:00:11.835: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar 1 00:00:11.711: %SYS-4-PUPDATECLOCK: Periodic Clock update with ROMMON failed, because size left in ROMMON (4294967295), size needed (29), error code (-1)
Stack trace:
using eeprom values
ddr init done
Passed.
PCIE0: link is up.
PCIE1: link is up.
WiFi Trainers
Hi Syed,
It looks like your AP is crashing before it even joins the WLC. I can see it is also trying to load the latest 12.x code available for the 1042 AP on cisco.com. Can you please clarify the following:
-What is the software version of WLC that you are using?
-Are there other 1042 AP's working correctly?
Best Regards,
www.wifitrainers.com
Learn from the Best To be the Best!
Change the way you look at wireless client connectivity forever by registering to watch this free webinar and also stand a chance to win our Wireless starter kit worth $8000 for free!!
Leo Laohoo
The "Mode" button was not held down long enough so the AP is NOT booting in ROMmon.
Currently, the AP is crashing and, possibly, due to the flash memory being FULL of the crashinfo files.  The only way out is to go into ROMmon and erasing the crashinfo files.
