AP-1121G stuck
jrobert
I have several 1121G ap's that seem to loop at boot. Following Cisco's directions and using their suggested tftp server, renamed an ios file, held the mode button till red, and the ap transferred the correct file size from tftp. Now, at boot, the ap goes directly to "no cisco ios image file" according to the led's. I repeat the process and the ap will contact the tftp server but will not transfer data. Is there any way to recover from this error ?
Jeff Roberts
jeffrey.roberts@coxhealth.com
mmellet
Level 3
Level 3
Use your Internet browser to access the Cisco Software Center at the following URL:
http://www.cisco.com/public/sw-center/sw-wireless.shtml
Locate the access point firmware and utilities section and click on the link for the 1100 or 1200 series access point.
Double-click the latest firmware image file, such as c1100-k9w7-tar.122-11.JA.tar for 1100 series access points or c1200-k9w7-tar.122-11.JA.tar for 1200 series access points.
Download the access point image file to a directory on your PC hard drive.
