AP 1200 Boot problem
jodilovell
Level 2
Level 2
Hi all,
I know this issue has been raised before but I haven't seen if there is a resolution to this.
I got a 1231 AP last week and it worked fine for a day, tried to boot it up this morning and it wasn't happy - gave me a red and orange light. When I consoled into it, it was at the boot loader prompt. I read about this issue so I tried two methods to get it to boot: just typing boot being the first one(!!) and the second one was to reboot it with it plugged into the LAN. Both times, it appears to start booting and then just hangs and nothing gets it out of this state. I get the following:
Loading "flash:/c1200-k9w7-mx.122-13.JA4/c1200-k9w7-mx.122-13.JA4"...###########################################################################################################################################################################################################################################################################################################################
File "flash:/c1200-k9w7-mx.122-13.JA4/c1200-k9w7-mx.122-13.JA4" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C1200 Software (C1200-K9W7-M), Version 12.2(13)JA4, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 16-Apr-04 12:22 by cmong
Image text-base: 0x00003000, data-base: 0x0053CF74
Initializing flashfs...
flashfs[1]: 144 files, 6 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 3692544
flashfs[1]: Bytes available: 4048896
flashfs[1]: flashfs fsck took 3 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
And thats where it stops... Does anyone know if there is some kind of solution to this or does it need to be RMA'd?? Note that nothing changed IOS-wise, since the day that it actually worked!
Thanks!!!
wdrootz
Level 9
Level 9
You might want to take a look in the wireless troubleshooting center.
I have done and couldn't find anything except the boot-loader problem. I did also check the bug toolkit and couldn't find anything.
At any rate, I've RMA'd the thing and just gotten another one. So far so good but I haven't heard good things about the 1200's. We'll see how it goes.
Thanks.
