AP management
jasonchang
Community Member
Hi,my customer would like to install AP ,but he want to do AP management or certification to make sure that AP which join to LAN is the right one ,
this management is also the prevention of replacement by any other improper AP
Is there any method to do this job
thanks a lot
gwcrook
Level 3
Level 3
Hope this helps. The answer is in WDS and WLSE.
• Radio management features on 802.11a, 802.11b, and 802.11g radios—Access points running Cisco
IOS Release 12.2(15)JA can participate in radio management using 802.11a, b, and g radios. Access
points configured for WDS interact with the WDS device on your wireless LAN. The WDS device
forwards radio data to and from the WLSE device or wireless network manager on your network.
Radio management includes these features, which are configured on your WLSE device:
– Rogue access point detection, including the rogue device’s IP and MAC addresses, SSID, and,
if it is connected to a Cisco device, the switch port to which the rogue is connected
– Self-healing wireless LAN; if an access point fails, nearby access points increase their transmit
power to cover the gap in your wireless LAN
– Client tracking to identify the access point to which each client device is associated
• Scanning-only mode—Access points running Cisco IOS Release 12.2(15)JA can act as scanners to
detect rogue access points and monitor radio traffic on your wireless LAN. Access points configured
as scanners participate in radio management but do not accept client associations.
Hi , thanks for your information ,
the switch port which connect rogue access point need to be shutdown when WLSE detect location of rogue access point ,
Is there anyone know the process how WLSE do switch port shutdown
