AP-1220 Power Problem
stmapes
Community Member
AP boots fine on ac power but drops power entirely upon connecting ethernet cable.
scottmac
Level 11
Level 11
I believe the 1220 uses pre-release POE and will not work with switches using the current Standard POE.
What switch / power injector are you using?
Good Luck
Scott
