AP 1300 in repeater mode problem
tanyotanev
I have a 1300 workin as root and second 1300 that works fine as non-root, but cannot work as repeater(association problem). Also some of the commands in 1300 guide are missing from real 1300 IOS.The IOS is 12.4 What could be the problem?
Thank you
andrew.prince
Level 10
Level 10
I stand corrected - but if you want to use the AP as a repeater - you need to set an infrastrcuture SSID. The AP needs to know which SSID to associate on when there is more that one SSID
