AP 1702i bug - I need a workaround...
Peter Ryznar
Hi community,
I found out after one week of testing:
My AP 1702i (autonomous, latest SW) doesn't allow my wireless devices (iphone, notebook) to reach some SSL/TLS sites like
https://businesswebmail.a1.net
or
https://www.bawagpsk.com
for example. Sometimes such a site can be reached once or twice after a reboot of the AP, but then it becomes unreachable. It doesn't even work with open auth and no encryption config, just primitive standard via easy setup wizzard (SSID open and no security). With another wlan ap (netgear) connected to my lan in parallel it works without any problem.
Could you please test to reach these websites (3x or 4x) and give me some feedback please... thx in advance
Peter
device:
CISCO AIR-CAP1702I-E-K9 (flashed to autonomous version)
System sw: ap3g2-k9w7-xx.153-3.JC2
Now that sadly is a problem. I can't help you with that, as I don't have any 1702i here, but you might want to try a much older image (yours is the most current one).
Try: ap3g2-k9w7-tar.153-3.JBB6.tar
MD5 Checksum: 935e389017645a1baf6062ce9f2d00db
I assume it should be fixed in the successor of the ap3g2-k9w7-xx.153-3.JC2 image, but it isn't out yet. I assume it might be out in the middle of August (when the 8.2MR2 is final).
You might want to get a Smartnet contract for 1 year, it's around 50€ (assuming you're from Austria). I'm not sure if you can also get download access by registering your serial number without a Smartnet. Here is the official download link:
https://software.cisco.com/download/release.html?mdfid=286281141&flowid=71622&softwareid=284180979&release=15.3.3-JC2&relind=AVAILABLE&rellifecycle=ED&reltype=latest
12 Replies 12
Philip D'Ath
WiFi is a layer 2 protocol.  It has no knowledge of layer 3 (ip addresses) and above.
You may have an issues, but it wont be directy related to WiFi.
Perhaps you have an IP address conflict (perhaps with the other system)?  Perhaps the 1702 is developing a hardware issue?
Thx Philip,
I know about wifi is layer 2 but there is also some routing happening in the AP (distribution of the packets from LAN to different wifi clients.
What I found out is the fact, that the wirless device sends a packet (SYN) through the AP to the server and the server replies with a (SYN ACK) packet, which I can trace at the LAN port of the AP. But this packet is not transmitted to the wifi client in this case (mostly...). I tested also the AP on another LAN with another adresses and a fresh setup but its the same issue. I think its a software bug in the IOS of the AP and it depends on the type of the replying server. You may test it also by trying to open a telnet session with " telnet bsmtp.a1.net 587 " command. Please try it by yourself if you have some time left.
thx again
Peter
The configuration of your AP could help.
In any case, you might have an MTU or Duplex issue between your AP and the device it is connected to, check if the speed is correct at 1 Gbps and that you have an MTU of 1500 on the next Layer 3 device.
Thx but first: are you able to reach these websites via cisco ap?
and
I checked both MTU and 1GBits + full duplex - and checked MTU by
"ping www.yahoo.com -f -l 1472" - works and therefor MTU = 1500.
The issue is nearly identical to Cisoc Bug: CSCuc02149
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuc02149
where exactly this error shows up at the console and I sniffered the same SYN ACK packet not being transmitted to the wireless client. But I'm not sure what it has to do with ipv6...
my config (primitive standar for testing):
! Last configuration change at 15:47:16 UTC Thu Jul 21 2016
version 15.3
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$Q7nI$rldmDg8kg9vCoRbrC5CRd/
no aaa new-model
no ip source-route
no ip cef
dot11 syslog
dot11 ssid MAR
   authentication open
   guest-mode
no ipv6 cef
username Cisco password 7 047802150C2E
bridge irb
interface Dot11Radio0
 no ip address
 ssid MAR
 antenna gain 0
 stbc
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio1
 no ip address
 shutdown
 antenna gain 0
 peakdetect
 no dfs band block
 channel dfs
 station-role root
 bridge-group 1
interface GigabitEthernet0
 no ip address
 duplex auto
 speed auto
 bridge-group 1
interface GigabitEthernet1
 no ip address
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 mac-address 00c1.64a4.5a3c
 ip address dhcp client-id GigabitEthernet0
 ipv6 address dhcp
 ipv6 address autoconfig
 ipv6 enable
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
 login local
 transport input all
end
I can reach both URLs over a controller based Cisco AP.
You do have IPv6 enabled on your BVI1, try to disable that, if you don't use it.
Also, you have your 5 GHz band disabled, I guess that is extra?
Also check this here: https://supportforums.cisco.com/document/61936/autonomous-ap-and-bridge-basic-configuration-template
They have configured a default gateway on the AP which you lack.
Only other thing left, try a different driver on the client side, I had very weird wireshark findings in the past with Intel drivers of the years 2014 and 2015, they were horrible.
thx again, very interesting that you can reach these sites. Would it be possible to get your config for comparison? There is maybe something additional when configured through a WLC...
Yes, I've tried all your hints but without success, always getting this issue and this error msg.
I tried also per iphone, android phone and per Lenovo laptop but always not reachable over cisco AP and always reachable over netgear wlan AP. I did siffing with microsoft network analyser and with wireshark, all the same.
maybe you may send me the working config per email: p.ryznar@yopmail.com
thx so much
Peter
This is the config, please note that it completely lacks the SSID configuration as it's in local mode. Please note, it's a 3702i model.
3702AC-1011-1#sh run
Building configuration...
Current configuration : 21351 bytes
! Last configuration change at 11:11:59 UTC Fri Jul 22 2016
version 15.3
no service pad
hostname 3702AC-1011-1
enable secret 5 here_is_a_password
aaa new-model
aaa authentication login default local
aaa session-id common
no ip routing
no ip cef
eap profile lwapp_eap_profile
 method fast
crypto pki trustpoint cisco-m2-root-cert
 revocation-check none
 rsakeypair Cisco_IOS_M2_MIC_Keys
crypto pki trustpoint Cisco_IOS_M2_MIC_cert
crypto pki trustpoint airespace-old-root-cert
 rsakeypair Cisco_IOS_MIC_Keys
crypto pki trustpoint airespace-device-root-cert
crypto pki trustpoint Cisco_IOS_MIC_cert
crypto pki certificate chain cisco-m2-root-cert
 certificate ca 01
        quit
crypto pki certificate chain Cisco_IOS_M2_MIC_cert
        quit
 certificate ca 02
         quit
username apadmin secret 5 here_is_a_password
ip ssh version 2
lldp run
bridge irb
 no ip route-cache
 antenna gain 0
 stbc
 ampdu transmit priority 1
 ampdu transmit priority 2
 ampdu transmit priority 3
 mbssid
 speed  6.0 9.0 12.0 basic-18.0 basic-24.0 basic-36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23.
 power local 4
 power client local
 packet retries 64 drop-packet
 fragment-threshold 2312
 station-role root
 no cdp enable
 no ip route-cache
 antenna gain 0
 peakdetect
 stbc
 mbssid
 speed  basic-18.0 basic-24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23. a1ss9 a2ss9 a3ss9
 power local 12
 power client local
 station-role root
 no cdp enable
 no ip route-cache
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 mac-address 74a2.e63c.cd2c
 ip address dhcp client-id BVI1
 no ip route-cache
 ipv6 address dhcp
 ipv6 enable
interface Virtual-WLAN0
 no ip route-cache
no ip http server
logging trap emergencies
logging origin-id string AP:74a2.e63c.cd2c
logging facility kern
logging host 255.255.255.255
bridge 1 protocol ieee
bridge 1 route ip
parser view capwap-config-view
 commands configure include all capwap
 commands exec include all enable
 commands exec include configure terminal
 commands exec include all show capwap
 commands exec include show running-config
line con 0
line vty 0 4
 transport input ssh
line vty 5 15
 transport input ssh
end
Just found this bug while reading the release notes for the controller 8.2MR2 beta:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCux92251
Description:
- AIR-CAP2702 with WLC 8.2 doesnt allow HTTPS client access
- 2702 AP using Flexconnect against a controller with 8.2.100 code, clients can't connect HTTPS sites, AP span port shows receiving GET/ACK packets, but on client capture we do not see ACK back, so client keeps on re-transmitting GETs
- Same setup with 1142 works
This might also affect your 1702 model, I think they run the same software.
Wow, I think this could be the bug affecting me...
But how to come to a workaround or a solution ?
I've no service contract with Cisco...
thx, I'll try the older version (download is possible for a partner of mine)
...I'll post the result here...
downgrade to
was the solution !
This version is ok and solves my problem -
thx so much @patoberli
