AP 1832 can't join to Wireless Controller 2554
thbinhvdc
I have problems: Access Point can't join to Wireless Controller
[*07/07/2019 08:25:21.0000] CAPWAP State: DTLS Setup
[*07/07/2019 08:25:21.0000] DTLS connection created sucessfully local_ip: 192.168.1.138 local_port: 5248 peer_ip: 192.168.1.10 peer_port: 5246
[*07/07/2019 08:26:18.0322] Wait DTLS timer has expired
[*07/07/2019 08:26:18.0322] Dtls session establishment failed
[*07/07/2019 08:26:18.0322] dtls_disconnect: ERROR shutting down dtls connection ...
[*07/07/2019 08:26:18.0322] CAPWAP State: DTLS Teardown
[*07/07/2019 08:26:18.0422] [DP] Deleting capwap datapath
[*07/07/2019 08:26:18.0422] CAPWAP data tunnel delete from forwarding succeeded
[*07/07/2019 08:26:22.7807] DTLS session cleanup completed. Restarting capwap state machine.
[*07/07/2019 08:26:22.7807] Previous CAPWAP state was DTLS Setup,numOfCapwapDiscoveryResp = 1.
[*07/07/2019 08:26:22.7807] Starting Discovery.
@thbinhvdc wrote:
Product Version.................................. 8.0.110.0
Upgrade the firmware of the controller.
Firmware support for the 1832 AP is 8.1.122.X and the controller is currently running 8.0.110.0.
5 Replies 5
Mark Elsen
 - Check current software version installed on the controller and whether it supports this AP model.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
Post the complete output to the following commands:
1. WLC: sh sysyinfo;
2. WLC: sh time; &
3. AP: sh version
Tks for you reply.
WLC:
show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... iConnect
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.1.10
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 0 days 0 hrs 45 mins 38 secs
System Timezone Location......................... (GMT -1:00) Azores
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... TH - Thailand
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +35 C
External Temperature............................. +43 C
Fan Status....................................... 4500 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 64:D8:14:DB:65:C0
Maximum number of APs supported.................. 75
System Nas-Id.................................... iConnect
WLC MIC Certificate Types........................ SHA1
3. AP: sh version
This product contains some software licensed under the
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
Cisco AP Software, (ap1g4), [wnbu-vmw-lnx-02:/san/BUILD/workspace/83MR4_Repost_Cheetah_CCO/label/corsica]
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon Jun 4 23:03:21 PDT 2018
ROM: Bootstrap program is U-Boot boot loader
BOOTLDR: U-Boot boot loader Version 31
f1-ap1 uptime is 0 days, 1 hours, 09 minutes
Last reload time : Sun Jul 7 08:51:26 UTC 2019
Last reload reason : Factory Reset
cisco AIR-AP1832I-H-K9 ARMv7 Processor rev 0 (v7l) with 967420/759568K bytes of memory.
Processor board ID KWC224809TD
AP Running Image : 8.3.143.0
Primary Boot Image : 8.3.143.0
Backup Boot Image : 0.0.0.0
2 Gigabit Ethernet interfaces
2 802.11 Radios
Radio FW version : c5d79906494f60ee03674c0779e5c30b
NSS FW version : NSS.AK.1.0.c10-00017-E_custC-1.67978.1
Base ethernet MAC Address : 70:18:A7:C4:54:28
Part Number : 0-0000-00
PCA Assembly Number : 074-104313-03
PCA Revision Number : 01
PCB Serial Number : KWC224809TD
Top Assembly Part Number : 074-104313-03
Top Assembly Serial Number : KWC224809TD
Top Revision Number : A0
Product/Model Number : AIR-AP1832I-H-K9
Best Regards
I upgraded and resolved this problem
