1111 WLAN Controller
Alex Pfeil
Level 10
Level 10
Is it possible to turn off the status lights on wireless access points that are connected to the 1111 WLAN controller? I was looking for the option, but I do not see it listed.
Alex
Alex Pfeil
Level 10
Level 10
You can do it from the 1111 SSH CLI. You can do it by AP or all of them per below example.
>config ap led-state disable all
Alex Pfeil
Level 10
Level 10
