AP-1852i-A-K9C cycling through green, red, and amber
mcv
Hello! I purchased a brand new AIR-AP1852I-A-K9C (product number on the Cisco box) and the description below is "Cisco Aironet Mobility Express 1850 Series". The AP boots up and is cycling through green, red, and amber (Discovery/join process in progress). The AP gets an IP from DHCP (matching the MAC on the box) and I can ping it, but can't see the SSID CiscoAirProvision or open a webpage on its IP. Tried to reset as per guide (holding the reset, power on, wait 20-60 secs, release reset), but no improvement. Unfortunately I do not have a console cable to connect to my Mac computer, so this limits my troubleshooting skills.
Sandeep Choudhary
your AP is in CAPWAP Mode (Need WLC to manage).
1. Paste the output of sh version command from AP
What you can do to resolve it: console to AP and convert it to Mobility express.
How to do it:
https://www.semfionetworks.com/blog/convert-a-cisco-capwap-ap-to-a-mobility-express-ap
http://itadminguide.com/convert-capwap-cisco-1852i-access-point-to-mobility-express/
Dont forget to rate helpful posts
Sandeep Choudhary
How to do it:
Thank you Sandeep!
I was convinced, based on the part #, that I purchased an AP with the ME firmware.
I placed my order for the AirConsole, I will then be able to access the console port on the AP.
Will keep this post updated with my results.
Here we go:
ROM: Bootstrap program is U-Boot boot loader
BOOTLDR: U-Boot boot loader Version 30
AP00B6.7088.0BE8 uptime is 0 days, 0 hours, 2 minutes
Last reload time   : Sun Jul 22 07:03:32 UTC 2018
Last reload reason : unknown
cisco AIR-AP1852I-A-K9 ARMv7 Processor rev 0 (v7l) with 997268/707260K bytes of memory.
Processor board ID KWC22270HMG
AP Running Image     : 8.5.131.0
Primary Boot Image   : 8.5.131.0
Backup Boot Image    : 0.0.0.0
AP Image type    : MOBILITY EXPRESS IMAGE
AP Configuration : MOBILITY EXPRESS CAPABLE
2 Gigabit Ethernet interfaces
2 802.11 Radios
Radio FW version : 5fd9df2ef70d087b014a57c17ecc942b
NSS FW version : wstephen,
Base ethernet MAC Address            : 00:B6:70:88:0B:E8
Part Number                          : 0-0000-00
PCA Assembly Number                  : 074-13149-03
PCA Revision Number                  : 01
PCB Serial Number                    : KWC22270HMG
Top Assembly Part Number             : 074-13149-03
Top Assembly Serial Number           : KWC22270HMG
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1852I-A-K9
Well updating the firmware to the latest version helped. Since it was a brand new AP with no config, after the firmware upgrade I did a hard reset. The CiscoAirProvision SSID finally came up, and I was able to configure the AP over the web console/wifi. 2 things I learned from this : 1) always have a console cable available for Cisco product, because the console is great source of information. 2) update to the latest firmware.
