AP 3702i Standalone
DNA Admin EG
hellp i need your help.
i have a standalone AP 3702i,
after configure ssid and every thing go normal when i change encryption mode to cipher (AES+TKIP) and put authentication key WPA2
the ssid not appear and can join it as hidden network what is the issue ...
would need to see your config, but most likely missing the command "
guest-mode
Take a look at https://thewlan.com.au/2016/09/27/configuring-a-cisco-ap-for-site-survey/
*****Help out other by using the rating system and marking answered questions as "Answered"*****
guest-mode
thanks alot we found that we did't enable  (mbssid guest-mode) under SSID and now we found it
DNA Admin EG
foud the solution with  (mbssid guest-mode)
