AP AIR-CAP1602i-c-k9 Aironet without controler
masto99net
Dear All
i wolud like to ask  about Aironet AIr-CAP1602i-c-k9 , how to setup and assign ip address without controller (standalone) . cause i already configure via console but EXEC general configure # configure terminal not display.
ar  1 00:16:51.973: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:16:51.977: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
AP1c6a.7aac.e691#
AP1c6a.7aac.e691#
AP1c6a.7aac.e691#
AP1c6a.7aac.e691#
AP1c6a.7aac.e691#
AP1c6a.7aac.e691#?
Exec commands:
  access-profile   Apply user-profile to interface
  capwap           capwap exec commands
  cd               Change current directory
  clear            Reset functions
  clock            Manage the system clock
  crypto           Encryption related commands.
  debug            Debugging functions (see also 'undebug')
  delete           Delete a file
  dir              List files on a filesystem
  disable          Turn off privileged commands
  do-exec          Mode-independent "do-exec" prefix support
  enable           Turn on privileged commands
  exit             Exit from the EXEC
  fsck             Fsck a filesystem
  help             Description of the interactive help system
  led              LED functions
  lock             Lock the terminal
  logging          Handles logging operations
  login            Log in as a particular user
  logout           Exit from the EXEC
  lwapp            lwapp exec commands
  mkdir            Create new directory
  monitor          Monitoring different system events
  more             Display the contents of a file
  name-connection  Name an existing network connection
  no               Disable debugging functions
  partition        Partition disk
  ping             Send echo messages
  pwd              Display current working directory
  release          Release a resource
  reload           Halt and perform a cold restart
  rename           Rename a file
  renew            Renew a resource
  rmdir            Remove existing directory
  save             Start to save raise_interrupt_level stack
  send             Send a message to other tty lines
  set              Set system parameter (not config)
  show             Show running system information
  systat           Display information about terminal lines
  terminal         Set terminal line parameters
  test             Test subsystems, memory, and interfaces
  traceroute       Trace route to destination
  undebug          Disable debugging functions (see also 'debug')
  upgrade          Upgrade commands
  verify           Verify a file
  where            List active connections
Sandeep Choudhary
HI I think its still in Lightweight mode. Can you paste the output of this command: sh version
Image:
k9w7 - autonomous  IOS
k9w8 – full lightweight IOS
How to configure:
Autonomous AP configuration: http://rscciew.wordpress.com/2014/05/24/single-ssid-configuration-on-autonomous-ap/
Dont forget to rate helpful posts
