AP Association problem
rochoa8aeg
Level 3
Level 3
I have 2 sites under my control with 2 to 3 AP's each. I am suddenly having issues associating to the AP even though I can see the ssid's fine, and the signal strength is excellent. When I attempt to connect the wireless client behavior attempts to grab an IP and sometimes it will ask for a password sometimes it will not.
I have been able to log-in to the AP by web and telnet, once in I cant seem to see any misconfigurations.
Can anyone assist me by providing me a troubleshooting list of things to check, or an article to read or any ideas as to why this is happening.
gmarogi
Level 9
Level 9
There are several reasons for a failed association.
Can you let me know the following information?
1. what security configuration you are using in your AP?. - 802.1x or 802.11?
2. If 802.1x is used, verify connectivity among the AP and RADIUS server and other required wired devices.
3. Send me the configurationof AP and the client and any associated devices
4. Sene me any valid debug output from the AP durign the process of association.
1) The security we are using is WPA.
2) We dont use a Radius server with this setup.
3) I have no debug info or client associated config. These users are band members who perform at a Theatre and are gone the next day.
I hope you can assist me with the information I have provided.
Current configuration : 3821 bytes
version 12.3
no service pad
service password-encryption
hostname AEGL-STRBLRM-AP1
no logging console
enable secret 5
$1$0LuF$ZTSzjT5XNqrBOXUpYb8P90
ip subnet-zero
aaa session-id common
dot11 vlan-name AEG-Users vlan 13
dot11 vlan-name Core vlan 10
dot11 vlan-name Guests vlan 100
dot11 ssid AEG
vlan 13
authentication open
authentication key-management wpa
accounting acct_methods
mbssid guest-mode
wpa-psk ascii 7
12385630473F2D36720A28246167
dot11 ssid StarlandGuest
vlan 100
authentication open
mbssid guest-mode
wpa-psk ascii 7
080069693A0D04051E0A02007D7C7C70
username aegusait privilege 15 secret 5
$1$M3e7$wQAvFTuKsKbfHwuhlIkHy/
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 13 mode ciphers tkip
encryption vlan 10 mode ciphers tkip
encryption vlan 100 mode ciphers tkip
ssid AEG
ssid StarlandGuest
mbssid
speed basic-1.0 basic-2.0 basic-5.5
6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0
48.0 54.0
station-role root
interface Dot11Radio0.10
encapsulation dot1Q 10 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.13
encapsulation dot1Q 13
no ip route-cache
bridge-group 13
bridge-group 13
bridge-group 13 block-unknown-source
no bridge-group 13 source-learning
no bridge-group 13 unicast-flooding
bridge-group 13 spanning-disabled
interface Dot11Radio0.100
encapsulation dot1Q 100
no ip route-cache
bridge-group 100
bridge-group 100
bridge-group 100 port-protected
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
bridge-group 100 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
hold-queue 80 in
interface FastEthernet0.10
no ip route-cache
bridge-group 1
interface FastEthernet0.13
no ip route-cache
bridge-group 13
interface FastEthernet0.100
no ip route-cache
bridge-group 100
interface BVI1
ip address 10.150.32.8 255.255.255.0
no ip route-cache
ip default-gateway 10.150.32.5
ip http server
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/sm
biz/prodconfig/help/eag
tacacs-server host 172.18.56.6 key 7
097A4B1B003612111909106B6A657A61
tacacs-server directed-request
control-plane
bridge 1 route ip
line con 0
login authentication telnet-order
line vty 0 4
line vty 5 15
end
