AP C9124AXI NOT JOINING CONTROLLER
H&M
Frequent Visitor
Frequent Visitor
Hello all,
I´m having issues trying to join a cisco C9124axi to cisco mobility express, I got the following output from cli:
AP488B.0A76.715C#[*01/22/2022 02:31:44.5321]
[*01/22/2022 02:31:44.5321] CAPWAP State: Discovery
[*01/22/2022 02:31:44.5352] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2022 02:31:44.5363] Discovery Response from 10.4.209.222
[*01/22/2022 02:31:44.5364] Discovery response from MWAR 'ORZ-WC-OT01' running version 8.10.151.0 is rejected.
[*01/22/2022 02:31:44.5364] Failed to decode discovery response(status = 4).
[*01/22/2022 02:31:44.5364] CAPWAP SM handler: Failed to process message type 2 state 2.
[*01/22/2022 02:31:44.5364] Failed to handle capwap control message from controller - status 4
[*01/22/2022 02:31:44.5364] Failed to process unencrypted capwap packet 0x55b99da000 from 10.4.209.222
[*01/22/2022 02:31:44.5364] Failed to send capwap message 0 to the state machine. Packet already freed.
Show version output
Cisco AP Software, (ap1g6a), C9124, RELEASE SOFTWARE
Copyright (c) 1986-2022 by Cisco Systems, Inc.
Compiled Fri Jul 30 02:53:42 PDT 2021
ROM: Bootstrap program is U-Boot boot loader
BOOTLDR: U-Boot boot loader Version 17
AP488B.0A76.715C uptime is 0 days, 0 hours, 2 minutes
Last reload time : Sat Jan 22 02:40:10 UTC 2022
Last reload reason : Failed to discover WLC after maximum attempt
cisco C9124AXI-A ARMv8 Processor rev 4 (v8l) with 1812508/1258868K bytes of memory.
Processor board ID FJC26042AEZ
AP Running Image : 17.6.1.13
Primary Boot Image : 17.6.1.13
Backup Boot Image : 0.0.0.0
Primary Boot Image Hash:
Backup Boot Image Hash:
3 Multigigabit Ethernet interfaces
2 802.11 Radios
1 Bluetooth Low Energy Integrated Radio
BLE Firmware Version : 2.7.19
Radio FW version : QC_IMAGE_VERSION_STRING=WLAN.HK.2.4-02036-QCAHKSWPL_SILICONZ-1
NSS FW version : NSS.HK.11.3-9-SF05156147-E_custC
Base ethernet MAC Address : 48:8B:0A:76:71:5C
Part Number : 0-0000-00
PCA Assembly Number : 074-125082-01
PCA Revision Number : A0
PCB Serial Number : FOC2551260T
Top Assembly Part Number : 068-102439-01
Top Assembly Serial Number : FJC26042AEZ
Top Revision Number : A0
Product/Model Number : C9124AXI-A
What could be the problem?
I don't think that model is supported on ME.  Take a look at the matrix and search 9124, it's toward the middle.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
-Scott
6 Replies 6
Scott Fella
What model is the ME?  Have you searched the forum, because there are some post regarding 91xx joining Mobility Express.
https://community.cisco.com/t5/wireless/wifi-6-ap-s-9115-9117-9120-with-mobility-express/td-p/3957212
https://community.cisco.com/t5/wireless/connecting-cisco-ios-ap-9100-to-mobility-express-controller/td-p/4010355
-Scott
H&M
Frequent Visitor
Frequent Visitor
Hello Scott, the mobility express software is running under a 2802i access point and it is running version 8.10.151.0
I already have some C9120 and C9115 access points joined the mobility express but now that Im trying to join the C9124axi I been having problems.
-Scott
Additional info:
Cisco Catalyst 9124AX Series Outdoor APs are supported on Cisco Catalyst 9800 wireless controller-based products
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/9124ax/install-guide/b-hig-9124ax/overview.html#c9124_features
-Scott
H&M
Frequent Visitor
Frequent Visitor
Thanks for your help Scott, you are right.
Rich R
Correct 9124 is not supported by ME.  Easiest place to check is table 1 of the release notes:
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/810/release_notes/b_ME_RN_810.html#me-supp-ap
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
