AP does not access
Reigota95
Community Member
I have an AP 1602i that just came in but can not access it via the Console. I put it in the net to catch the DHCP but it exchange IP every 1 ~ 2 minutes.
I do not have parent in my environment.
One would have any idea what it is or what to do to access it.
HTTP access not.
5 Replies 5
Sandeep Choudhary
use these setting:
Bits per sec    :  9600
Data bits       :     8
Parity          :  none
Stop bits       :     1
Flow control    :  none
and try to access via console:
username: Cisco
Password: Cisco
Don't forget to rate helpful posts
I am with this setting in Putty, but when I try to access via console it just opens the terminal but nothing appears not to enter any of the command.
You can reset the AP via the mode button as well
1. Disconnect power (the power jack for external power or the Ethernet cable for in-line power) from the access point.
2. Press and hold the MODE button while you reconnect power to the access point.
3. Hold the MODE button until the Status LED turns amber (approximately 1 to 2 seconds), and release the button. All access point settings return to factory defaults.
https://popravak.wordpress.com/2014/08/26/resetting-cisco-capwaplwap-access-point-to-factory-defaults/
I have also done this procedure and yet was not. There's more something that can be done?
No, thats more them enough to get access.
