AP does not join after priming
Hi all,
I have that problem, that the AP does not join to WLC after the priming process.
I get the following error logs:
*Mar 3 20:40:20.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.31.31.155 peer_port: 5246
*Mar 3 20:40:20.655: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.31.31.155 peer_port: 5246
*Mar 3 20:40:20.655: %CAPWAP-5-SENDJOIN: sending Join Request to 172.31.31.155
*Mar 3 20:40:25.655: %CAPWAP-5-SENDJOIN: sending Join Request to 172.31.31.155
*Mar 3 20:40:26.347: %DTLS-5-ALERT: Received WARNING : Close notify alert from 172.31.31.155
*Mar 3 20:40:26.347: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.31.31.155:5246
*Mar 3 20:40:26.519: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Mar 3 20:40:26.527: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar 3 20:40:27.519: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar 3 20:40:27.547: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar 3 20:40:27.555: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Mar 3 20:40:27.563: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar 3 20:40:28.547: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar 3 20:40:28.555: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar 3 20:40:28.607: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar 3 20:40:29.607: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar 3 20:40:36.515: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
Does anybody had the same problem and can help me?
Best Regards,
Michael
11 Replies 11
Sandeep Choudhary
paste the output of these commands:
sh sysinfo from WLC
sh version from AP
Dont forget to rate helpful posts
Here is the sh version from AP:
sh version on AP:
AP-KNA-VWG-01>show version
Cisco IOS Software, C2700 Software (AP3G2-K9W8-M), Version 15.3(3)JA10, RELEASE                   SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Tue 23-Aug-16 02:04 by prod_rel_team
ROM: Bootstrap program is C2700 boot loader
BOOTLDR: C2700 Boot Loader (AP3G2-BOOT-M) LoaderVersion 15.2(4)JB5m, RELEASE SOF                  TWARE (fc2)
AP-KNA-VWG-01 uptime is 15 hours, 40 minutes
System image file is "flash:/ap3g2-k9w8-mx.153-3.JA10/ap3g2-k9w8-xx.153-3.JA10"
Last reload reason:
--More--
*Mar  6 10:25:12.663: %CAPWAP-5-SENagree to comply with applicable laws and regu                  lations. If you are unable
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-AP2702I-UXK9 (PowerPC) processor (revision A0) with 376814K/134656K by                  tes of memory.
Processor board ID FCW2028N9CV
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.0.140.0
Access Point Type: World Mode
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes ding Join Request to 172.31.31.155
*Mar  6 10:25:13.599: %DTLS-5-ALERT: Received WARNING : Close notify alert from                   172.31.31.155
*Mar  6 10:25:13.of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:F6:63:5B:A8:6C
Part Number                          : 73-15824-03
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC2027128J
Top Assembly Part Number             : 068-100395-01
Top Assembly Serial Number           : FCW2028N9CV
Top Revision Number                  : A0
Product/Model Number       599: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Al                  ert to 172.31.31.155:5246          : AIR-AP2702I-UXK9
Configuration register is 0xF
AP-KNA-VWG-01>
1. Check the time on WLC
2. If its having mesh image then add mac address of AP to wlc.
if still fails then paste the complete bootup process here from AP console.
Here is a overview from WLC:
i will provide you de outputs asap.
Thx!
here is the bootprocess of the affected AP
it must be related to Regulatory related issue.
did you primed the AP ?
also paste the output of dir or dir flash: from AP.
Here the output for dir:
Directory of flash:/
    2  -rwx         282   Jan 1 1970 00:18:38 +00:00  info
    3  drwx        2176   Mar 3 2017 22:03:21 +00:00  ap3g2-k9w8-mx.153-3.JA10
    4  -rwx           0   Mar 1 1993 00:00:59 +00:00  config.txt
    5  -rwx       72855   Mar 5 2017 17:37:13 +00:00  event.log
   38  drwx         576   Jan 1 1970 00:18:34 +00:00  ap3g2-rcvk9w8-mx
    6  -rwx         965   Mar 5 2017 17:35:02 +00:00  lwapp_mm_mwar_hash.cfg
    7  drwx         320   Mar 4 2017 16:19:09 +00:00  configs
    8  -rwx          74   Mar 5 2017 17:35:00 +00:00  capwap-saved-config
   76  -rwx          64   Mar 5 2017 17:37:07 +00:00  sensord_CSPRNG0
    9  -rwx       50224   Mar 1 1993 00:02:34 +00:00  lwapp_non_apspecific_reap.cfg
   10  -rwx         280   Mar 5 2017 17:35:01 +00:00  lwapp_officeextend.cfg
   11  -rwx          74   Mar 5 2017 17:37:00 +00:00  capwap-saved-config-bak
   80  -rwx          64   Mar 5 2017 17:37:07 +00:00  sensord_CSPRNG1
   14  -rwx         235   Mar 6 2017 15:01:50 +00:00  env_vars
   13  -rwx       95008   Mar 1 1993 00:02:34 +00:00  lwapp_reap.cfg
   15  -rwx           0   Mar 4 2017 16:12:41 +00:00  ce
   16  -rwx       12312   Mar 6 2017 15:01:50 +00:00  private-multiple-fs
   17  -rwx       64960   Mar 5 2017 07:28:52 +00:00  event.capwap
   19  -rwx       95008   Mar 5 2017 18:11:33 +00:00  lwapp_reap.cfg.bak
check these posts:
https://supportforums.cisco.com/discussion/12707491/nightmare-unprimed-access-points
https://supportforums.cisco.com/discussion/12740226/ux-ap-join-issue-invalid-license-configuration-request
thanks for the links.
I´ll test it and answer if it worked.
Hello @MichaelSicklinger,
Did you Find a solution for this?, I have the exact same problem everytime I prime a 2700 AP.
The workaround (Stupid One) that I've found is:
  1st   Prime the AP
  2nd Factory Reset the AP with Mode Button
  3rd The AP will Register to WLC "Primed", But It shows Like this: ap priming.PNG
When I errase all the config via CLI/WLC, the ap will register, then after been primed It will not register again.
