AP Fallback not working with Cisco 4402
Chellis Dodge
Hello everyone,
I have an issue with AP Fallback not working with two Cisco 4402-50 WLC's.  Here is the senerio:
Site 1 has a 4402 (WLC01) running software 7.0.220.0 with 48 associated access points. AP Fallback is enabled in Controller > General and all 48 AP's are set to Critical failover with WLC01 being the primary controller and WLC02 (at site 2) being the secondary.
Site 2 is the location of WLC02 which is also running software 7.0.220.0 but has 0 ap's associated and also had AP Fallback set to enabled.
Your typical active/passive setup
The problem is when WLC01 goes down all of the AP's fail over to WLC02, however when the connection is restored to WLC01 we have to manually reboot each access point in order for them to reassociate back to the primary controller. Isn't AP Fallback enabled suppose to allow the AP's to move back to the primary controller once connection is reestablished?
Thanks in advance.
-Chellis
Scott Fella
Make sure the mobility is up and master controller is disabled. Now what you need to make sure is that on the high availability tab, that the wlc name is identical to the wlc hostname. This is case sensitive.
Scott Fella
Sent from my iPhone
-Scott
15 Replies 15
Scott Fella
Scott Fella
Sent from my iPhone
-Scott
I checked and Master Controller is disabled on both controllers. I verified the hostnames aginst the high availablility tab and they were correct. The only issue I did notice is I do not have the WLC hostnames in DNS when I tried to ping them. Could this cause the issue? Lastly I do have a mobility group created for everything on WLC01
You need the mobility on wlc2 also. DNS is not needed.
Scott Fella
Sent from my iPhone
-Scott
WLC02 does have a mobility group configured, but it dosn't match the one on WLC01 do I need to configure the same mobility groups on both controllers?
As long as wlc2 has wlc 1 Mac, ip and mobility name you should be fine.
Scott Fella
Sent from my iPhone
-Scott
I added the MAC, IP, and Group Name of WLC2 to WLC1 and it has  "Control and Data Path Down" listed under status. I've verified that  they can ping each other where they are located across the WAN on  different subnets. Do you know what needs to happen next? Thanks for  your help on this Scott.
-Chellis
can you post the output of :
show mobility summary
from both WLC?
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
WLC 2 the Failover at site 2  (there is another controller at this site as well)
Symmetric Mobility Tunneling (current) .......... Enabled
Symmetric Mobility Tunneling (after reboot) ..... Enabled
Mobility Protocol Port........................... 16666
Default Mobility Domain.......................... MODO2
Multicast Mode .................................. Disabled
Mobility Domain ID for 802.11r................... 0x93dd
Mobility Keepalive Interval...................... 10
Mobility Keepalive Count......................... 3
Mobility Group Members Configured................ 2
Mobility Control Message DSCP Value.............. 0
Controllers configured in the Mobility Group
MAC Address        IP Address       Group Name                        Multicast IP     Status
00:22:55:91:b4:a0  10.107.180.4    MODO1                                 0.0.0.0          Up
00:22:55:91:b6:40  10.107.180.2    MODO1                                 0.0.0.0          Up
WLC1 the primary controller at the first site
Default Mobility Domain.......................... MODO1
Mobility Domain ID for 802.11r................... 0x64fd
00:22:55:90:3c:60  10.101.180.2     MODO1                                0.0.0.0          Up
00:22:55:91:b4:a0  10.107.180.4     MODO2                                0.0.0.0          Control and Data Path Down
You have the wrong mobility group name.
Scott Fella
Sent from my iPhone
-Scott
Thanks that fixed it, it's showing both mobility groups as UP, so now I just need to test if the AP's will fall back to the primary controller once connection is restored.
Thanks Scott for all your help, hopefully this one is solved.
No problem. The output that Steve asked for showed the issue:)
Scott Fella
Sent from my iPhone
-Scott
Change MODO2 to MODO1
Scott Fella
Sent from my iPhone
-Scott
Well from each wlc, can you do an eping and mping. You might be blocking the udp ports.
Scott Fella
Sent from my iPhone
-Scott
Yes just tried a eping and mping both was all all replies were successful.
