AP for mobility express
Hello, I need only one AP with mobility express to support for 40-50 clients.
I saw datasheet for cisco 9115 that supports the built-in controller is it possible to buy 9115 and that AP acts as controller and AP same device? If not which cisco AP you can suggest
2 Accepted Solutions
Rasika Nayanajith
Yes, you can use 9100 series AP. The name has changed from "Mobility Express" to "EWC - Embedded Wireless Controller"
https://www.cisco.com/c/en/us/solutions/collateral/enterprise-networks/mobility-express/guide-c07-741338.html
Rasika
*** Pls rate all useful responses ***
5 Replies 5
Rasika Nayanajith
Rasika
Thank you!
one more thing. what is the difference between these APs: C9115AXI C9115AXE?
Sandeep Choudhary
yes it will act as AP & WLC on same device at same time.
Please select the AP from these models as per your requrement:
https://www.cisco.com/c/en/us/products/wireless/access-point-controller-selector.html?indoor_access_points_network_type_and_size_(remote_users,_small,_midsize,_or_large_networks)=mission-critical_enterprise|multi-dwelling|remote_access_or_branch_work...
Dont forget to rate helpful posts
Thank you!
I saw this discussion, they wrote that 9115 not have mobility express.?
https://community.cisco.com/t5/wireless-and-mobility/configuration-of-cisco-ap-9115/td-p/3923188
