AP issue
mzedanmzedan
Frequent Visitor
Frequent Visitor
Spoiler
Hi Dears,
I have a problem with AP Air-CAP2602e-e-K9
I can't access it via console, and these symbols are appearing.
Kindly note that the AP is in standalone mode.
Scott Fella
If your baud rate is set to 9600 8N1, then it looks like that so was flashed somehow and no way to recover that.
-Scott
Dear Scoot,
Thanks for your reply.
Exactly, I had set the settings to 9600, 8N1
Do you mean that AP is not available to use again?
make sure your flow control is set to none.  Swithces and routers allow it to be RTS/CTS, but the AP needs flow control to be off.
and please also try with some other console cables(USB-->rs232).
Dontf orget to rate helpful posts
