AP losing connectivity to Controller
Rob Johnson
2602 AP loosing connectivity to 5508 running 7.4.110.0.
This very well could be happening during higher traffic periods
-AP has been moved to another port and even to another switch
-AP was even replace with a new one
-Apparently there are other APs on the segment staying joined up
Looking for hints to troubleshoot
2 Accepted Solutions
Scott Fella
Well you have done almost everything except for actually for the cable run itself. Replace patch cables and use canned air to blow of the Ethernet port on the AP and also the biscuit jack if one has been used. When the AP looses connectivity to the WLC and look at the switch show inline power (Cisco switch) and make sure the device is showing up right and not showing IEEE. If it does, it's usually a layer 1 issue. Depending in the switch you have, you can run a TDR test.
https://supportforums.cisco.com/docs/DOC-18983
This is Leo's favorite:)
-Scott
Scott Fella
-Scott
Rob Johnson
Alright guys. Thanks for the responses.
I'll get into this a little more tomorrow and look to see if there are anymore clues to help me figure this one out.
take care:::
Rob,
I asked one Cisco (back in 2011) if they can add TDR function to CPI but all I heard is cricket.  TDR will benefit CPI because CPI now monitors switch ports.
