AP MAC adresses in flexconnect group configuration not showing the cli config file
Niels Marien
Dear,
Could someone please check and verify of this is normal.
When I export the config from the GUI or CLI, I don't see the which AP are listed under which Flexconnect group.
I need to have this information to automatically update the config on the N + 1 redundancy controller.
Now I have to visually check every Flexconnect group and then copy past the mac of the AP to the other controller…. ☹
Kr
Niels
WC01) >show run-config commands
flexconnect group 00027A add flexconnect group 00027A ap add 34:db:fd:xx:xx:xx flexconnect group 00027A ap add 34:db:fd:xx:xx:xx flexconnect group 00027A radius ap server-key <hidden> ...
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.0.152.0
Can see the AP MAC in flexconnect config.
superego
What command did you use to show the running config in CLI?
Try:
***for the full running config***
***for flexconnect config***
grep include "flexconnect group" 'show run-config commands'
***Please mark this as an acceptable solution if it helped.  Thanks.***
There is a part of the flexconnect config, but no AP's mac.
Is there in your setup? Because that was the question in the tread.
