ā08-15-2011 09:23 AM - edited ā07-03-2021 08:34 PM
Just moved to new ip address and subnet. On the controller interface which I gave the AP manager 10.100.0.38 and the management 10.100.0.39. From windows 2008 NAP authenication, which IP do I point to? Thanks
ā08-15-2011 12:02 PM
Hello Hugh,
The management interface will be the proper address to define as a Radius client for your windows 2008 NPS server. Authentication packets will be sourced from the management interface.
The ap-manager interface is simply the termination point for all of the lwapp/capwap tunnels between your WLC and the APs.
-Patrick Croak
Wireless TAC
ā08-15-2011 09:05 PM
Yup!
Pat +5
I will add...
Your APs will terminate to the ap manager. So if you ever have any firewall moves or changes you will want to consider this ip / interface.
If you have the new 5508s, you dont need AP managers.
ā08-17-2011 09:55 AM
Thanks for the replies. I having another issue. My WLC 2100 show action on the rear panel (green flashing light) how ever I cannot ping it. Yesterday I could login to the device but today I cannot. What command line do I use to troubleshoot
ā08-17-2011 10:14 AM
Hi Hugh,
You will want to check that your interface settings are correct on the WLC, if you can get on the console:
"show interface summary"
"show interface detailed management"
Then you will want to also verify your switchport configuration that it is connected to.
One of the most common mistakes is the VLAN tag -- if the VLAN is configured as native on the switchport, you will want it to be set to 0 on the WLC. (config interface vlan management x)
-Pat
