AP monitor mode
TuralLachinov
I have one question, I have wireless network with 45 APs, and I want to add some APs to use them in sniffer or monitor mode,
would you please recommend, how many APs I need to sniff al the wireless network by design?
Thanks in advance
BR
Tural L
George Stefanick
General rule of tumb is for every 6 access points add 1 monitor.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Thank you very much George,
Do you have any documentation on this please ?
BR
Tural L
I just spent the last 30 minutes trying to find the document that I read that suggest 1/6 deployment for monitor aps. But unfortunately I am having little luck finding it.
I did however, blog about this subject and conducted testing myself.
http://www.my80211.com/home/2010/1/9/why-you-should-consider-monitor-access-points-as-part-of-you.html
It was great info, I would like to ask you to share your experience with me if have any additional info
Thanks in advance
BR
Tural
