USB Wireless Card
buck.tyler
Community Member
I currently have a client that is searching for a solution to wireless connectivity issues. Nothing showing up to be a problem in NCS, site survey showed no dead areas in coverage. The device they are using to connect is too small to fit an internal NIC inside of, no PCI slots available. The only option looks to be an external usb wireless adapter.
Has anyone had a positive experience or have specific product info on a USB wireless adapter that works well in enterprise?
I have found this one to have some good feedback, but was wondering if anyone else had a better product in mind.
http://homestore.cisco.com/viewproduct.htm?productId=134743390&sourceid=tv1_se_gbase&ci_src=17588969&ci_sku=134743390&ci_gpa=pla&gclid=CLvao4Hu77QCFelDMgodxgcAjQ
Thank you!
Tyler
Scott Fella
Those should work fine... I have these that we use for testing, but might be a bit expensive.
http://www.amazon.com/Proxim-Orinoco-8494-802-11A-Adapter/dp/B0046TAAY2
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Like Scott mentioned the proxim USB is the way to go. I would avoid the linksys and netgear in a enterprise environment.
Thanks guys. I will forward this information on!
