ap not joining controller air-cap1702I-E-K9
abdellahgartoumi65815
Community Member
hello,
i have probleme in one from APs cant join controller this is the boot sequance summary
btw i can ping the controller and other machines in the network.
thank you
IOS Bootloader - Starting system.
flash is writable
Antigua Lite Board P2
40MB format
Tide XL MB - 40MB of flash
Xmodem file system is available.
flashfs[0]: 239 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 19061760
flashfs[0]: Bytes available: 22096896
flashfs[0]: flashfs fsck took 10 seconds.
Base Ethernet MAC address: a4:6c:2a:f5:78:78
Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx"...#########################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
40MB format
flashfs[0]: flashfs fsck took 11 seconds.
flashfs[1]: 0 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 12257280
flashfs[1]: Bytes used: 1024
flashfs[1]: Bytes available: 12256256
flashfs[1]: flashfs fsck took 0 seconds.
Unable to locate IOS image with name **xx**.
Boot CMD: 'boot flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx'
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"...########################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx" uncompressed and installed, entry point: 0x1003000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C1700 Software (AP3G2-RCVK9W8-M), Version 15.3(3)JA3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Thu 19-Feb-15 10:27 by prod_rel_team
40MB format
Initializing flashfs...
flashfs[2]: 239 files, 8 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 40900608
flashfs[2]: Bytes used: 19061760
flashfs[2]: Bytes available: 21838848
flashfs[2]: flashfs fsck took 11 seconds.
flashfs[2]: Initialization complete.
flashfs[3]: 0 files, 1 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 11999232
flashfs[3]: Bytes used: 1024
flashfs[3]: Bytes available: 11998208
flashfs[3]: flashfs fsck took 1 seconds.
flashfs[3]: Initialization complete....done Initializing flashfs.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1702I-E-K9 (PowerPC) processor (revision A0) with 376810K/134656K bytes of memory.
Processor board ID FCZ1924Y03F
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.0.115.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: A4:6C:2A:F5:78:78
Part Number : 73-16776-01
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC19205TRB
Top Assembly Part Number : 068-05568-02
Top Assembly Serial Number : FCZ1924Y03F
Top Revision Number : A0
Product/Model Number : AIR-CAP1702I-E-K9
% Please define a domain-name first.
ipv6 enable
% Invalid input detected at '^' marker.
ipv6 address autoconfig
ipv6 address dhcp
Press RETURN to get started!
*Mar 1 00:00:13.423: APAVC: Initial WLAN Buffers Given to System is 2500
*Mar 1 00:00:13.475: APAVC: WlanPAKs 42878 RadioPaks 42270
*Mar 1 00:00:13.475: Starting Ethernet promiscuous mode
*Mar 1 00:00:13.479: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar 1 00:00:15.471: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:15.611: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:15.643: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed state to up
*Mar 1 00:00:15.655: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
lwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:00:15.799: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:16.639: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:20.459: DPAA Initialization Complete
*Mar 1 00:00:20.459: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar 1 00:00:21.459: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:23.459: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar 1 00:00:24.459: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*Mar 1 00:00:27.639: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*Mar 1 00:00:28.639: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:28.711: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.30.30.163, mask 255.255.255.0, hostname APa46c.2af5.7878
bridge-group 1 source-learning
%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar 1 00:00:34.475: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
%Error opening flash:/capwap-saved-config (No such file or directory)
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (35.194.21.47) (42.54.123.217)
Not in Bound state.
*Mar 1 00:02:08.999: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
*Mar 1 00:02:12.071: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 172.30.30.163, mask 255.255.255.0, hostname APa46c.2af5.7878
*Mar 1 00:02:35.387: %CDP_PD-4-POWER_OK: 15.4 W power - NON_CISCO-NO_CDP_RECEIVED inline power source
*Mar 1 00:02:37.387: %LINK-5-CHANGED: Interface GigabitEthernet1, changed state to administratively down
APa46c.2af5.7878>
8 Replies 8
Sandeep Choudhary
paste the output of these commands:
sh sysinfo from WLC
Sh time from WLC
Dont forget to rate helpful posts
craig.beck
Level 6
Level 6
Do you have DNS or DHCP Option 43 configured to tell APs what the WLC IP is?
the ip address of the WLC is 172.30.30.2
Mark Elsen
              >%CDP_PD-4-POWER_OK: 15.4 W power - NON_CISCO-NO_CDP_RECEIVED inline power source
 Albeit seemingly  counter intuitive this may indicate wrong power received from power source. What power source is used for this AP ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
the power source is the rj-45 cable
 - Excuse me ? You either use PoE from switch or power injector !
   M.
       Beauty and terror
      Just keep going
       No feeling is final
im juste using the rj45 cable to powerup the AP and console cable for commands
POST THE OUTPUT OF THE COMMANDS WHICH WE ASKED BEFORE:
