Ap not joining controller
Solanin19
Hello everyone,
I have a issue with my AP1815W-E-K9 not joining my  2504 cisco controller.
On the join phase statistics i can read:
Lwapp discovery request rejected
discovery request decoding with subnet rboadcast and wrong AP ip address.
The setup
The configuration on the controller interface:
On the switch:
ip dhcp pool vlan15
network 192.168.15.0 255.255.255.0
default-router 192.168.15.1
ip dhcp pool vlan42
network 192.168.42.0 255.255.255.0
default-router 192.168.42.1
interface GigabitEthernet1/0/15
description uplink_wlc_int1
switchport mode trunk
spanning-tree portfast disable
interface GigabitEthernet1/0/18
switchport trunk allowed vlan 42
interface GigabitEthernet1/0/17
description uplink_AP
switchport access vlan 42
switchport mode access
Can anyone provide any clarification or recommendations around this for me?
Cheers,
François
dont delete it.  Just put AP in vlan 15 and try again.
switchport access vlan 15
Dont forget to rate helpful posts
13 Replies 13
Sandeep Choudhary
paste the output of this command: sh sysinfo from WLC
Also paste the complete bootup process form AP console.
Info: you need minimum version of 8.4.100.0 to join 1815W AP to WLC.
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.5.131.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 20.0
OUI File Last Update Time........................ Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... cisco-labo
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.15.254
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 54 days 23 hrs 40 mins 2 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin,        Rome, Vienna
--More-- or (q)uit
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... BE  - Belgium
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +31 C
External Temperature............................. +34 C
Fan Status....................................... 3200 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
OUI Classification Failure Count................. 0
Burned-in MAC Address............................ a
Maximum number of APs supported.................. 75
System Nas-Id.................................... cisco-labo
WLC MIC Certificate Types........................ SHA1/SHA2
I don't know how to access to the consol of the AP, because i don't have the cable to connect the unusual port:port.PNG
AP and WLC are in diff VLANS.
whcih method are using to join AP to WLC ?
Where did you configure the DHCP scope for APs ?
My suggestion is to use option 43 on vlan 42.
if you are using DHCP scope on cisoc switch for vlan 42 the use these...
ip dhcp pool <pool name>
network <ip network> <netmask>
default-router <default-router IP address>
dns-server <dns server IP address>
option 43 hex f104c0a80ffe
Post the WLC command of "sh time".
- The AP must reach the WLC via the cisco switch
- the dhcp is configured on the switch
  I use the option 43, no change
(Cisco Controller) >show time
Time............................................. Mon Sep 10 11:44:37 2018
Timezone delta................................... 0:0
Timezone location................................ (GMT +2:00) Jerusalem
NTP Servers
    NTP Version..................................     3
    NTP Polling Interval.........................     600
     Index     NTP Key Index                  NTP Server                Status          NTP Msg Auth Status
Time and date is not correct.
This is why the WLC won't let the AP join.
I corrected the time , it's the same time now on the controller and the switch. Still not working.
Connect a console cable and reboot the AP.
Post the entire boot-up process.
you need to correct the OPTION 43. something wrong you are doing here!!!!!
Aletrnate:  try to put AP in vlan 15(same as WLC) and try again....I am sure it will join to WLC.
I did configure  like you told me the option 43:
"ip dhcp pool <pool name>
option 43 hex f104c0a80ffe"
Should i delete it now ?
you configure tie option43 with the wlc adres in the vlan 15
but the AP is directly connected on vlan 42
-> rboadcast for address vlan15 is not accepted on vlan42
is the switch configured for any routing between vlan15 and vlan 42?
(no "ip routing" in the config section displayed)
if not, the ap cannot reach the controller
-> you have different solutions
1) enable routing (+ disable vlan 15 for ap management)
2) change ap vlan to vlan15 (+ disable vlan 15 for ap management)
3) remove option 43 in the dhcp scope ( discovery is by broadcast)
4) change option 43 to vlan42 address
jain.manish94
try
int gi 1/0/17
switchport trunk native vlan 100
shut
no shut the port.
what is native vlan ?
