AP not joining WLC
Antonio Macia
Level 7
Level 7
We are migrating APs from a 2504 to a vWLC controller. Both on the same version. Doing test with a single AP by manually changing the WLC IP on the AP, it is not joining the vWLC. We have accepted the EULA to avoid licenses issues. These is the output of the sh info, sh time in the WLC and the sh version and sh ip interface brief on the AP, as well as the output of the debug capwap events enabled, debug capwap packet enable and debug pm pki enable:
APCISCO_181#show version
APCISCO_181 uptime is 0 days, 0 hours, 1 minutes
cisco AIR-AP1832I-E-K9 ARMv7 Processor rev 0 (v7l) with 997268/796072K bytes of memory.
Processor board ID KWC24170P6K
AP Running Image : 8.5.182.0
Primary Boot Image : 8.5.182.0
Backup Boot Image : 8.5.171.0
1 Gigabit Ethernet interfaces
2 802.11 Radios
Radio FW version : 5598e146cdc7a5aa268722d45211b677
NSS FW version : NSS.AK.C.CS-3-fix5
Product/Model Number : AIR-AP1832I-E-K9
APCISCO_181#show ip interface brief
Interface IP-Address Method Status Protocol Speed Duplex
wired0 10.10.30.181 static up up 1000 full
wifi0 n/a n/a up up n/a n/a
wifi1 n/a n/a up up n/a n/a
show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.5.182.0
RTOS Version..................................... 8.5.182.0
Bootloader Version............................... 8.5.1.85
Emergency Image Version.......................... 8.5.182.0
OUI File Last Update Time........................ Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... mad-wifi-controller-01
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1631
IP Address....................................... 172.26.15.3
IPv6 Address..................................... ::
System Up Time................................... 0 days 0 hrs 46 mins 52 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... ES - Spain
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 5
Number of Active Clients......................... 0
OUI Classification Failure Count................. 0
Memory Current Usage............................. 15
Memory Average Usage............................. 15
CPU Current Usage................................ 0
CPU Average Usage................................ 0
Flash Type....................................... Compact Flash Card
Flash Size....................................... 1073741824
Burned-in MAC Address............................
Maximum number of APs supported.................. 200
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1
Licensing Type................................... RTU
vWLC config...................................... Small
(Cisco Controller) >show sysinfo
System Up Time................................... 0 days 0 hrs 46 mins 56 secs
--More-- or (q)uit
(Cisco Controller) >show time
Time............................................. Mon Oct 3 13:55:44 2022
Timezone delta................................... 0:0
Timezone location................................ (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
NTP Servers
NTP Version.................................. 3
NTP Polling Interval......................... 600
Index NTP Key Index NTP Server Status NTP Msg Auth Status
2 0 188.87.125.90 In Progress AUTH DISABLED
*spamApTask7: Oct 03 13:58:02.870: <<<< Start of CAPWAP Packet >>>>
*spamApTask7: Oct 03 13:58:02.870: CAPWAP Control mesg Recd from 10.10.30.181, Port 5248
*spamApTask7: Oct 03 13:58:02.870: HLEN 4, Radio ID 0, WBID 1
*spamApTask7: Oct 03 13:58:02.870: Msg Type : CAPWAP_DISCOVERY_REQUEST
*spamApTask7: Oct 03 13:58:02.870: Msg Length : 191
*spamApTask7: Oct 03 13:58:02.870: Msg SeqNum : 0
*spamApTask7: Oct 03 13:58:02.870: Type : CAPWAP_MSGELE_DISCOVERY_TYPE, Length 1
*spamApTask7: Oct 03 13:58:02.870: Discovery Type : CAPWAP_DISCOVERY_TYPE_STATIC_CONFIG
*spamApTask7: Oct 03 13:58:02.870: Type : CAPWAP_MSGELE_WTP_BOARD_DATA, Length 73
*spamApTask7: Oct 03 13:58:02.870: Vendor Identifier : 0x00409600
*spamApTask7: Oct 03 13:58:02.870: WTP_SERIAL_NUMBER : AIR-AP1832I-E-K9
*spamApTask7: Oct 03 13:58:02.870: Type : CAPWAP_MSGELE_WTP_DESCRIPTOR, Length 40
*spamApTask7: Oct 03 13:58:02.870: Maximum Radios Supported : 2
*spamApTask7: Oct 03 13:58:02.870: Radios in Use : 2
*spamApTask7: Oct 03 13:58:02.870: Encryption Capabilities : 0x00 0x01
*spamApTask7: Oct 03 13:58:02.870: Type : CAPWAP_MSGELE_WTP_FRAME_TUNNEL, Length 1
*spamApTask7: Oct 03 13:58:02.870: WTP Frame Tunnel Mode : NATIVE_FRAME_TUNNEL_MODE
*spamApTask7: Oct 03 13:58:02.870: Type : CAPWAP_MSGELE_WTP_MAC_TYPE, Length 1
*spamApTask7: Oct 03 13:58:02.870: WTP Mac Type : SPLIT_MAC
*spamApTask7: Oct 03 13:58:02.870: Type : CAPWAP_DOT11_MSGELE_WTP_RADIO_INFORMATION, Length 5
*spamApTask7: Oct 03 13:58:02.870: Radio ID : 0
*spamApTask7: Oct 03 13:58:02.870: Radio Type : RADIO_80211A
*spamApTask7: Oct 03 13:58:02.870: Radio ID : 1
*spamApTask7: Oct 03 13:58:02.870: Radio Type : RADIO_80211B
*spamApTask7: Oct 03 13:58:02.870: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 10
IE : UNKNOWN IE 207
*spamApTask7: Oct 03 13:58:02.870: IE Length : 4
*spamApTask7: Oct 03 13:58:02.870: Decode routine not available, Printing Hex Dump
*spamApTask7: Oct 03 13:58:02.870: 00000000: 01 00 00 01 ....
*spamApTask7: Oct 03 13:58:02.870: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 19
IE : RAD_NAME_PAYLOAD
*spamApTask7: Oct 03 13:58:02.870: IE Length : 13
*spamApTask7: Oct 03 13:58:02.870: Rad Name :
*spamApTask7: Oct 03 13:58:02.870: APCISCO_181
*spamApTask7: Oct 03 13:58:02.870: <<<< End of CAPWAP Packet >>>>
*spamApTask7: Oct 03 13:58:02.870: 14:16:9d:1d:66:40 Discovery Request from 10.10.30.181:5248
*spamApTask7: Oct 03 13:58:02.870: 14:16:9d:1d:66:40 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 200, MaxLicense=200 joined Aps =0
*spamApTask7: Oct 03 13:58:02.870: 14:16:9d:1d:66:40 apType = 58 apModel: AIR-AP1832I-E-K9
*spamApTask7: Oct 03 13:58:02.870: 14:16:9d:1d:66:40 apType: Ox3a bundleApImageVer: 8.5.182.0
*spamApTask7: Oct 03 13:58:02.870: 14:16:9d:1d:66:40 version:8 release:5 maint:182 build:0
*spamApTask7: Oct 03 13:58:02.871: 14:16:9d:1d:66:40 Discovery Response sent to 10.10.30.181 port 5248
*spamApTask7: Oct 03 13:58:02.871: 14:16:9d:1d:66:40 Discovery Response sent to 10.10.30.181:5248
*spamApTask7: Oct 03 13:58:02.871: <<<< Start of CAPWAP Packet >>>>
*spamApTask7: Oct 03 13:58:02.871: CAPWAP Control mesg Recd from 10.10.30.181, Port 5248
*spamApTask7: Oct 03 13:58:02.871: HLEN 4, Radio ID 0, WBID 1
*spamApTask7: Oct 03 13:58:02.871: Msg Type : CAPWAP_DISCOVERY_REQUEST
*spamApTask7: Oct 03 13:58:02.871: Msg Length : 191
*spamApTask7: Oct 03 13:58:02.871: Msg SeqNum : 0
*spamApTask7: Oct 03 13:58:02.871: Type : CAPWAP_MSGELE_DISCOVERY_TYPE, Length 1
*spamApTask7: Oct 03 13:58:02.871: Discovery Type : CAPWAP_DISCOVERY_TYPE_STATIC_CONFIG
*spamApTask7: Oct 03 13:58:02.871: Type : CAPWAP_MSGELE_WTP_BOARD_DATA, Length 73
*spamApTask7: Oct 03 13:58:02.871: Vendor Identifier : 0x00409600
*spamApTask7: Oct 03 13:58:02.871: WTP_SERIAL_NUMBER : AIR-AP1832I-E-K9
*spamApTask7: Oct 03 13:58:02.871: Type : CAPWAP_MSGELE_WTP_DESCRIPTOR, Length 40
*spamApTask7: Oct 03 13:58:02.871: Maximum Radios Supported : 2
*spamApTask7: Oct 03 13:58:02.871: Radios in Use : 2
*spamApTask7: Oct 03 13:58:02.871: Encryption Capabilities : 0x00 0x01
*spamApTask7: Oct 03 13:58:02.871: Type : CAPWAP_MSGELE_WTP_FRAME_TUNNEL, Length 1
*spamApTask7: Oct 03 13:58:02.871: WTP Frame Tunnel Mode : NATIVE_FRAME_TUNNEL_MODE
*spamApTask7: Oct 03 13:58:02.871: Type : CAPWAP_MSGELE_WTP_MAC_TYPE, Length 1
*spamApTask7: Oct 03 13:58:02.871: Type : CAPWAP_DOT11_MSGELE_WTP_RADIO_INFORMATION, Length 5
*spamApTask7: Oct 03 13:58:02.871: Radio ID : 0
*spamApTask7: Oct 03 13:58:02.871: Radio Type : RADIO_80211A
*spamApTask7: Oct 03 13:58:02.871: Radio ID : 1
*spamApTask7: Oct 03 13:58:02.871: Radio Type : RADIO_80211B
*spamApTask7: Oct 03 13:58:02.871: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 10
IE : UNKNOWN IE 207
*spamApTask7: Oct 03 13:58:02.871: IE Length : 4
*spamApTask7: Oct 03 13:58:02.871: Decode routine not available, Printing Hex Dump
*spamApTask7: Oct 03 13:58:02.871: 00000000: 01 00 00 01 ....
*spamApTask7: Oct 03 13:58:02.871: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 19
*spamApTask7: Oct 03 13:58:02.871: IE Length : 13
*spamApTask7: Oct 03 13:58:02.871: Rad Name :
*spamApTask7: Oct 03 13:58:02.871: APCISCO_181
*spamApTask7: Oct 03 13:58:02.871: <<<< End of CAPWAP Packet >>>>
*spamApTask7: Oct 03 13:58:02.871: 14:16:9d:1d:66:40 Discovery Request from 10.10.30.181:5248
*spamApTask7: Oct 03 13:58:02.871: 14:16:9d:1d:66:40 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 200, MaxLicense=200 joined Aps =0
*spamApTask7: Oct 03 13:58:02.871: 14:16:9d:1d:66:40 apType = 58 apModel: AIR-AP1832I-E-K9
*spamApTask7: Oct 03 13:58:02.871: 14:16:9d:1d:66:40 apType: Ox3a bundleApImageVer: 8.5.182.0
*spamApTask7: Oct 03 13:58:02.871: 14:16:9d:1d:66:40 version:8 release:5 maint:182 build:0
(Cisco Controller) >*spamApTask7: Oct 03 13:58:02.871: 14:16:9d:1d:66:40 Discovery Response sent to 10.10.30.181:5248
*spamApTask7: Oct 03 13:59:33.049: <<<< Start of CAPWAP Packet >>>>
*spamApTask7: Oct 03 13:59:33.049: CAPWAP Control mesg Recd from 172.26.21.26, Port 54253
*spamApTask7: Oct 03 13:59:33.049: HLEN 4, Radio ID 0, WBID 1
*spamApTask7: Oct 03 13:59:33.049: Msg Type : CAPWAP_PRIMARY_DISCOVERY_REQUEST
*spamApTask7: Oct 03 13:59:33.049: Msg Length : 159
*spamApTask7: Oct 03 13:59:33.049: Msg SeqNum : 0
*spamApTask7: Oct 03 13:59:33.049: Type : CAPWAP_MSGELE_DISCOVERY_TYPE, Length 1
*spamApTask7: Oct 03 13:59:33.049: Discovery Type : CAPWAP_DISCOVERY_TYPE_STATIC_CONFIG
*spamApTask7: Oct 03 13:59:33.049: Type : CAPWAP_MSGELE_WTP_BOARD_DATA, Length 62
*spamApTask7: Oct 03 13:59:33.049: Vendor Identifier : 0x00409600
*spamApTask7: Oct 03 13:59:33.049: WTP_SERIAL_NUMBER : AIR-CAP1602I-E-K9
*spamApTask7: Oct 03 13:59:33.049: Type : CAPWAP_MSGELE_WTP_DESCRIPTOR, Length 40
*spamApTask7: Oct 03 13:59:33.049: Maximum Radios Supported : 2
*spamApTask7: Oct 03 13:59:33.049: Radios in Use : 2
*spamApTask7: Oct 03 13:59:33.049: Encryption Capabilities : 0x00 0x01
*spamApTask7: Oct 03 13:59:33.049: Type : CAPWAP_MSGELE_WTP_FRAME_TUNNEL, Length 1
*spamApTask7: Oct 03 13:59:33.049: WTP Frame Tunnel Mode : NATIVE_FRAME_TUNNEL_MODE
*spamApTask7: Oct 03 13:59:33.049: Type : CAPWAP_MSGELE_WTP_MAC_TYPE, Length 1
*spamApTask7: Oct 03 13:59:33.049: WTP Mac Type : SPLIT_MAC
*spamApTask7: Oct 03 13:59:33.049: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 10
IE : UNKNOWN IE 207
*spamApTask7: Oct 03 13:59:33.049: IE Length : 4
*spamApTask7: Oct 03 13:59:33.049: Decode routine not available, Printing Hex Dump
*spamApTask7: Oct 03 13:59:33.049: 00000000: 01 00 00 01 ....
*spamApTask7: Oct 03 13:59:33.049: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 16
*spamApTask7: Oct 03 13:59:33.049: IE Length : 10
*spamApTask7: Oct 03 13:59:33.049: <<<< End of CAPWAP Packet >>>>
*spamApTask7: Oct 03 13:59:33.049: 00:af:1f:b6:8d:70 Primary Discovery Request from 172.26.21.26:54253
*spamApTask7: Oct 03 13:59:33.049: 00:af:1f:b6:8d:70 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 200, MaxLicense=200 joined Aps =0
*spamApTask7: Oct 03 13:59:33.049: 00:af:1f:b6:8d:70 apType = 29 apModel: AIR-CAP1602I-E-K9
*spamApTask7: Oct 03 13:59:33.049: 00:af:1f:b6:8d:70 apType: Ox1d bundleApImageVer: 8.5.182.0
*spamApTask7: Oct 03 13:59:33.049: 00:af:1f:b6:8d:70 version:8 release:5 maint:182 build:0
*spamApTask7: Oct 03 13:59:33.049: 00:af:1f:b6:8d:70 Primary Discovery Response sent to 172.26.21.26:54253
*sshpmLscTask: Oct 03 13:59:57.611: sshpmLscTask: LSC Task received a message 4
*sshpmLscTask: Oct 03 14:02:00.395: sshpmLscTask: LSC Task received a message 4
*spamApTask4: Oct 03 14:02:23.649: <<<< Start of CAPWAP Packet >>>>
*spamApTask4: Oct 03 14:02:23.649: CAPWAP Control mesg Recd from 172.26.21.26, Port 54254
*spamApTask4: Oct 03 14:02:23.649: HLEN 4, Radio ID 0, WBID 1
*spamApTask4: Oct 03 14:02:23.649: Msg Type : CAPWAP_DISCOVERY_REQUEST
*spamApTask4: Oct 03 14:02:23.649: Msg Length : 159
*spamApTask4: Oct 03 14:02:23.649: Msg SeqNum : 0
*spamApTask4: Oct 03 14:02:23.649: Type : CAPWAP_MSGELE_DISCOVERY_TYPE, Length 1
*spamApTask4: Oct 03 14:02:23.649: Discovery Type : CAPWAP_DISCOVERY_TYPE_STATIC_CONFIG
*spamApTask4: Oct 03 14:02:23.649: Type : CAPWAP_MSGELE_WTP_BOARD_DATA, Length 62
*spamApTask4: Oct 03 14:02:23.649: Vendor Identifier : 0x00409600
*spamApTask4: Oct 03 14:02:23.649: WTP_SERIAL_NUMBER : AIR-CAP1602I-E-K9
*spamApTask4: Oct 03 14:02:23.649: Type : CAPWAP_MSGELE_WTP_DESCRIPTOR, Length 40
*spamApTask4: Oct 03 14:02:23.649: Maximum Radios Supported : 2
*spamApTask4: Oct 03 14:02:23.649: Radios in Use : 2
*spamApTask4: Oct 03 14:02:23.649: Encryption Capabilities : 0x00 0x01
*spamApTask4: Oct 03 14:02:23.649: Type : CAPWAP_MSGELE_WTP_FRAME_TUNNEL, Length 1
*spamApTask4: Oct 03 14:02:23.649: WTP Frame Tunnel Mode : NATIVE_FRAME_TUNNEL_MODE
*spamApTask4: Oct 03 14:02:23.649: Type : CAPWAP_MSGELE_WTP_MAC_TYPE, Length 1
*spamApTask4: Oct 03 14:02:23.649: WTP Mac Type : SPLIT_MAC
*spamApTask4: Oct 03 14:02:23.649: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 10
IE : UNKNOWN IE 207
*spamApTask4: Oct 03 14:02:23.650: IE Length : 4
*spamApTask4: Oct 03 14:02:23.650: Decode routine not available, Printing Hex Dump
*spamApTask4: Oct 03 14:02:23.650: 00000000: 01 00 00 01 ....
*spamApTask4: Oct 03 14:02:23.650: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 16
*spamApTask4: Oct 03 14:02:23.650: Vendor Identifier : 0x00409600
*spamApTask4: Oct 03 14:02:23.650: IE Length : 10
*spamApTask4: Oct 03 14:02:23.650: Rad Name :
*spamApTask4: Oct 03 14:02:23.650: APCISCO_26
*spamApTask4: Oct 03 14:02:23.650: <<<< End of CAPWAP Packet >>>>
*spamApTask4: Oct 03 14:02:23.650: 00:af:1f:b6:8d:70 Discovery Request from 172.26.21.26:54254
*spamApTask4: Oct 03 14:02:23.650: 00:af:1f:b6:8d:70 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 200, MaxLicense=200 joined Aps =0
*spamApTask4: Oct 03 14:02:23.650: 00:af:1f:b6:8d:70 apType = 29 apModel: AIR-CAP1602I-E-K9
*spamApTask4: Oct 03 14:02:23.650: 00:af:1f:b6:8d:70 apType: Ox1d bundleApImageVer: 8.5.182.0
*spamApTask4: Oct 03 14:02:23.650: 00:af:1f:b6:8d:70 version:8 release:5 maint:182 build:0
*spamApTask4: Oct 03 14:02:23.650: 00:af:1f:b6:8d:70 Discovery Response sent to 172.26.21.26 port 54254
*spamApTask4: Oct 03 14:02:23.650: 00:af:1f:b6:8d:70 Discovery Response sent to 172.26.21.26:54254
*spamApTask4: Oct 03 14:02:26.653: <<<< Start of CAPWAP Packet >>>>
*spamApTask4: Oct 03 14:02:26.653: CAPWAP Control mesg Recd from 172.26.21.26, Port 54254
*spamApTask4: Oct 03 14:02:26.653: HLEN 4, Radio ID 0, WBID 1
*spamApTask4: Oct 03 14:02:26.653: Msg Type : CAPWAP_DISCOVERY_REQUEST
*spamApTask4: Oct 03 14:02:26.653: Msg Length : 159
*spamApTask4: Oct 03 14:02:26.653: Msg SeqNum : 0
*spamApTask4: Oct 03 14:02:26.653: Type : CAPWAP_MSGELE_DISCOVERY_TYPE, Length 1
*spamApTask4: Oct 03 14:02:26.653: Discovery Type : CAPWAP_DISCOVERY_TYPE_UNKNOWN
*spamApTask4: Oct 03 14:02:26.653: Type : CAPWAP_MSGELE_WTP_BOARD_DATA, Length 62
*spamApTask4: Oct 03 14:02:26.653: Vendor Identifier : 0x00409600
*spamApTask4: Oct 03 14:02:26.653: WTP_SERIAL_NUMBER : AIR-CAP1602I-E-K9
*spamApTask4: Oct 03 14:02:26.653: Type : CAPWAP_MSGELE_WTP_DESCRIPTOR, Length 40
*spamApTask4: Oct 03 14:02:26.653: Maximum Radios Supported : 2
*spamApTask4: Oct 03 14:02:26.653: Radios in Use : 2
*spamApTask4: Oct 03 14:02:26.653: Encryption Capabilities : 0x00 0x01
*spamApTask4: Oct 03 14:02:26.653: Type : CAPWAP_MSGELE_WTP_FRAME_TUNNEL, Length 1
*spamApTask4: Oct 03 14:02:26.653: WTP Frame Tunnel Mode : NATIVE_FRAME_TUNNEL_MODE
*spamApTask4: Oct 03 14:02:26.653: Type : CAPWAP_MSGELE_WTP_MAC_TYPE, Length 1
*spamApTask4: Oct 03 14:02:26.653: WTP Mac Type : SPLIT_MAC
*spamApTask4: Oct 03 14:02:26.653: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 10
IE : UNKNOWN IE 207
*spamApTask4: Oct 03 14:02:26.653: IE Length : 4
*spamApTask4: Oct 03 14:02:26.653: Decode routine not available, Printing Hex Dump
*spamApTask4: Oct 03 14:02:26.653: 00000000: 01 00 00 01 ....
*spamApTask4: Oct 03 14:02:26.653: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 16
*spamApTask4: Oct 03 14:02:26.653: IE Length : 10
*spamApTask4: Oct 03 14:02:26.653: Rad Name :
*spamApTask4: Oct 03 14:02:26.653: APCISCO_26
*spamApTask4: Oct 03 14:02:26.653: <<<< End of CAPWAP Packet >>>>
*spamApTask4: Oct 03 14:02:26.653: 00:af:1f:b6:8d:70 Discovery Request from 172.26.21.26:54254
*spamApTask4: Oct 03 14:02:26.653: 00:af:1f:b6:8d:70 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 200, MaxLicense=200 joined Aps =0
*spamApTask4: Oct 03 14:02:26.653: 00:af:1f:b6:8d:70 apType = 29 apModel: AIR-CAP1602I-E-K9
*spamApTask4: Oct 03 14:02:26.653: 00:af:1f:b6:8d:70 apType: Ox1d bundleApImageVer: 8.5.182.0
*spamApTask4: Oct 03 14:02:26.653: 00:af:1f:b6:8d:70 version:8 release:5 maint:182 build:0
*spamApTask4: Oct 03 14:02:26.653: 00:af:1f:b6:8d:70 Discovery Response sent to 172.26.21.26 port 54254
*spamApTask4: Oct 03 14:02:26.653: 00:af:1f:b6:8d:70 Discovery Response sent to 172.26.21.26:54254
*spamApTask4: Oct 03 14:02:26.670: <<<< Start of CAPWAP Packet >>>>
*spamApTask4: Oct 03 14:02:26.670: CAPWAP Control mesg Recd from 172.26.21.26, Port 54254
*spamApTask4: Oct 03 14:02:26.670: HLEN 4, Radio ID 0, WBID 1
*spamApTask4: Oct 03 14:02:26.670: Msg Type : CAPWAP_DISCOVERY_REQUEST
*spamApTask4: Oct 03 14:02:26.670: Msg Length : 159
*spamApTask4: Oct 03 14:02:26.670: Msg SeqNum : 0
*spamApTask4: Oct 03 14:02:26.670: Type : CAPWAP_MSGELE_DISCOVERY_TYPE, Length 1
*spamApTask4: Oct 03 14:02:26.670: Discovery Type : CAPWAP_DISCOVERY_TYPE_STATIC_CONFIG
*spamApTask4: Oct 03 14:02:26.670: Type : CAPWAP_MSGELE_WTP_BOARD_DATA, Length 62
*spamApTask4: Oct 03 14:02:26.670: Vendor Identifier : 0x00409600
*spamApTask4: Oct 03 14:02:26.670: WTP_SERIAL_NUMBER : AIR-CAP1602I-E-K9
*spamApTask4: Oct 03 14:02:26.670: Type : CAPWAP_MSGELE_WTP_DESCRIPTOR, Length 40
*spamApTask4: Oct 03 14:02:26.670: Maximum Radios Supported : 2
*spamApTask4: Oct 03 14:02:26.671: Radios in Use : 2
*spamApTask4: Oct 03 14:02:26.671: Encryption Capabilities : 0x00 0x01
*spamApTask4: Oct 03 14:02:26.671: Type : CAPWAP_MSGELE_WTP_FRAME_TUNNEL, Length 1
*spamApTask4: Oct 03 14:02:26.671: WTP Frame Tunnel Mode : NATIVE_FRAME_TUNNEL_MODE
*spamApTask4: Oct 03 14:02:26.671: Type : CAPWAP_MSGELE_WTP_MAC_TYPE, Length 1
*spamApTask4: Oct 03 14:02:26.671: WTP Mac Type : SPLIT_MAC
*spamApTask4: Oct 03 14:02:26.671: Vendor Identifier : 0x00409600
IE : UNKNOWN IE 207
*spamApTask4: Oct 03 14:02:26.671: IE Length : 4
*spamApTask4: Oct 03 14:02:26.671: Decode routine not available, Printing Hex Dump
*spamApTask4: Oct 03 14:02:26.671: 00000000: 01 00 00 01 ....
*spamApTask4: Oct 03 14:02:26.671: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 16
*spamApTask4: Oct 03 14:02:26.671: <<<< End of CAPWAP Packet >>>>
*spamApTask4: Oct 03 14:02:26.671: 00:af:1f:b6:8d:70 Discovery Request from 172.26.21.26:54254
*spamApTask4: Oct 03 14:02:26.671: 00:af:1f:b6:8d:70 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 200, MaxLicense=200 joined Aps =0
*spamApTask4: Oct 03 14:02:26.671: 00:af:1f:b6:8d:70 apType = 29 apModel: AIR-CAP1602I-E-K9
*spamApTask4: Oct 03 14:02:26.671: 00:af:1f:b6:8d:70 apType: Ox1d bundleApImageVer: 8.5.182.0
*spamApTask4: Oct 03 14:02:26.671: 00:af:1f:b6:8d:70 version:8 release:5 maint:182 build:0
*spamApTask4: Oct 03 14:02:26.671: 00:af:1f:b6:8d:70 Discovery Response sent to 172.26.21.26 port 54254
*spamApTask4: Oct 03 14:02:26.671: 00:af:1f:b6:8d:70 Discovery Response sent to 172.26.21.26:54254
*spamApTask4: Oct 03 14:02:26.671: <<<< Start of CAPWAP Packet >>>>
*spamApTask4: Oct 03 14:02:26.671: CAPWAP Control mesg Recd from 172.26.21.26, Port 54254
*spamApTask4: Oct 03 14:02:26.671: HLEN 4, Radio ID 0, WBID 1
*spamApTask4: Oct 03 14:02:26.671: Msg Length : 159
*spamApTask4: Oct 03 14:02:26.671: Msg SeqNum : 0
*spamApTask4: Oct 03 14:02:26.671: Type : CAPWAP_MSGELE_DISCOVERY_TYPE, Length 1
*spamApTask4: Oct 03 14:02:26.671: Discovery Type : CAPWAP_DISCOVERY_TYPE_UNKNOWN
*spamApTask4: Oct 03 14:02:26.671: Type : CAPWAP_MSGELE_WTP_BOARD_DATA, Length 62
*spamApTask4: Oct 03 14:02:26.671: Type : CAPWAP_MSGELE_WTP_DESCRIPTOR, Length 40
*spamApTask4: Oct 03 14:02:26.671: Maximum Radios Supported : 2
*spamApTask4: Oct 03 14:02:26.671: Type : CAPWAP_MSGELE_VENDOR_SPECIFIC_PAYLOAD, Length 10
*spamApTask4: Oct 03 14:02:26.671: IE Length : 10
*spamApTask4: Oct 03 14:02:26.671: Rad Name :
*spamApTask4: Oct 03 14:02:26.671: APCISCO_26
*sshpmLscTask: Oct 03 14:04:03.271: sshpmLscTask: LSC Task received a message 4
Mark Elsen
 - (v)WLC GUI>>Secuirty>>AAA>AP policies>>Add> ? (AP mac addr) and check if it joins.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
It doesn't work. I tried adding the MAC even if there is no AP policy configuration.
Thx.
