AP not Registering
All my APs have been functioning well but after power outage one of them won't join the controller. Instead of showing greem light when ready its flicking between red and blue.
What could be the problem?
Thanks in advance.
8 Replies 8
ledzepp817
Level 2
Level 2
Are the APs set up for DHCP or do they have static IPs?
Abha Jha
Led blinking RED and BLUE means there is a FLASH file system failure. Here below a link
for your reference. Table 1.
http://www.cisco.com/en/US/docs/wireless/access_point/1140/quick/guide/ap1140gsg.html#wp46
485
Rasika Nayanajith
If you could get the AP console output to see what's going on
Rasika
Leo Laohoo
What kind of AP is this?  1140?
Flashing red & blue light means the AP is unable to bootup properly.  It could be in ROMmon.  If the AP is powered using PoE it could be one of the bugs affecting 1140.
If you have a PoE switch, then post the output to the commadn "sh power inline".  Your AP should be UNABLE to negotiate to PoE.  If this is the case, shut down the interface, wait for approximately 5 to 7 seconds and re-enable the port.
Let us know how this goes.  If it still doesn't work, then we need to go into the second step and check TDR.
Hi Guys,
AP:                     2602i
Controller:                     2504
APs using DHCP to acquire addresses
APs using power adapters (no PoE)
AP in same LAN as controller
In the event that there has been Flash system file failure what is the possible remedy?
Also what is and how do we check TDR?
I haven't managed to get console output but will post it as soon as I get it.
\\Kelvin
That'll depend on the exact model of your Cisco switch.
Hi Leo,
I have tried this specific AP on different switches including switch ports where other APs are working fine. It's just this specific one that is misbehaving. With that I would like to believe this has nothing to do with the switch. Tell me if I am right
Ok, how about if you console into the AP?
